Old 07-11-2013, 01:31 AM
rxpdavid rxpdavid is offline
Trim Level: Laraime
Color: BK
rxpdavid is on a distinguished road
Suckie69
What all did you remove to get to the bulbs?
Old 07-13-2013, 04:34 PM
buckmaster buckmaster is offline
Trim Level: Laramie Longhorn
Color: Deep Cherry PearlCoat / White Gold
Rep:16
buckmaster is on a distinguished road
Originally Posted by rxpdavid View Post
Suckie69
There are a lot of youtube videos about headlight removal and hid conversion. It is really a pretty easy mod.
I just finished installing 55W 5000K low and high beam hids from Retro Solutions. The only real headache is finding a good mounting area for the resistors, which do get pretty hot. They recommend mounting the resistors on metal for that reason. The right side has plenty of space to drill and mount the resistors. The left side is a problem because of the proximity or all of the plastic body parts and the fact that most of the factory wiring bundles are located in that location. What I ended up doing is to mount both (high and low) resistors for the left side on a metal stalk and suspended it below the fuse box just off of the inner fender. I did mount the stalk to plastic and I will be monitoring it to see if it gets too hot. Don't want to melt any plastic.
I am not sure where others have ended up mounting these resistors, but since most don't do highs as I did, (most seem to just do the low projectors and or fogs) they only have one resistor per side to worry about, not two per side as I did.
This fixes the weak light output that seem to plague these trucks. It is a tremendous difference, before and after.
Old 07-13-2013, 09:29 PM
bigbody's Avatar
bigbody bigbody is offline
Vehicle: 2013 Ram 1500 Laramie
Color: Black/gray
bigbody is on a distinguished road
I'm curios if you can replace the bulb in the factory projectors to make them any brighter, I know it won't be as bright as hiss but may be enough for people not wanting to go hid
2013 RAM 1500 Laramie, sunroof, 3:55gears, undercover se, avs in channel, 30% tint all around
Old 07-13-2013, 09:52 PM
Rep:16
One of the problems with creating brighter lights using filament type bulbs, like the I/R halogens in the 2013 rams is that increasing brightness with a filament means more heat. More heat means melt-city in the plastic housings the bulbs are mounted in. That is why HIDs are so popular because they create higher light output w/o creating more heat. In fact, I am told HIDs run cooler per watt of power used. I am curious why Ram did not use this type of lighting in these trucks. I am sold on HIDs.
Old 07-13-2013, 10:19 PM
Arth's Avatar
Arth Arth is offline
Color: Mineral Gray Metallic
Rep:2028
I think Ram, like Ford did, Will eventually go to HID's. I honestly think this was just a marketing thing so when they do a refresh or redesign down the road or just go into a new model year it is something to add to the list of new features.
Chrome... in moderation.
Old 07-13-2013, 10:38 PM
plumcrazy73's Avatar
plumcrazy73 plumcrazy73 is offline
Vehicle: 2013 Ram 1500 2WD Crew Cab
Trim Level: SLT w/Big Horn EQ GP
Color: True Blue Pearl
Rep:119
plumcrazy73 will become famous soon enoughplumcrazy73 will become famous soon enough
yea but is fords Halogen HIDs like Dodges is, if so that is just to get the projector look , they could have went true HIDS for the same upcharge but chose to go cheap and charge for the good stuff
Old 07-13-2013, 10:46 PM
Rep:119
I mounted my resistors, on exhaust straps, the universal type with the holes, that you can get from advance and such. bent an L into it, mounted them (2 per side) put them on the frame right behind the headlights. drilled 2 holes, and mounted them with self tapping sheet metal screws, grounded them there , then hit them with some paint over the sheet metal screws.
Old 07-17-2013, 04:16 PM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
Nemmisis1 Do you have any pics of your install? How long did it take? What did you do on the high beams?
Thanks,
David
Hopefully it attached
Old 07-17-2013, 04:18 PM
Color: BLACK
Rep:51
Another one with the cut out
Old 07-17-2013, 04:24 PM
Color: BLACK
Rep:51
If you used a canbus kit you wouldn't of needed any damn relay or resistors... The forums are here for help READ!!!! Canbus kit jis simple plug play... Period... Look up my 100 dollar eBay kit.. I have everything there.... I also got yelled at my moderators because I gave everyone a GREAT CHEAP (price wise) and they thought I was getting kickback...lol but some of th vendors might of gotten tight because of loss$$$$.... Now watch ill get blasted for this to.
2013, bulbs, projectors, ram sport
