Old 04-26-2013, 10:15 AM
RedRobin RedRobin is offline
Vehicle: 2007 Dodge Ram
RedRobin is on a distinguished road
Default 4X4 problems! Wont lock in!
hey guys. i had to put my truck into 4Hi last weekend and it worked just fine, but this week whenever i tried to put it in all it does is just blink on the dash. I use my 4 wheel drive alot so i really need a solution! thanks guys. any help is needed
RedRobin
Old 04-26-2013, 11:43 AM
whilightning's Avatar
whilightning whilightning is offline
Vehicle: 2012 Dodge Ram express
Trim Level: Express quad cab
Color: Bright white clear coat
whilightning is on a distinguished road
I had the same problem with my truck, it would just blink and not lock in after a few seconds like usual. I was trying a 100 different things, and neutral was my solution. I shifted into neutral(on the tree, not the button by the 4WD dial) and ithasn't happened since. I hope its the same situation for you, good luck
Old 04-26-2013, 12:19 PM
ridgerunnerseoinc ridgerunnerseoinc is offline
Vehicle: 2010 2500
Rep:108
ridgerunnerseoinc will become famous soon enoughridgerunnerseoinc will become famous soon enough
Try putting it in and out of R a few times slowly, giving it time to "work". I've had sucess with this trick on a lot of 4X4 trucks getting in and out of 4WD. U can also try putting it in 4 low too.
1500, 4 wheel drive, 4x4, dodge, problems
