Old 04-24-2013, 11:27 PM
MrRam's Avatar
MrRam MrRam is offline
Vehicle: 2005 dodge ram 1500
Trim Level: thunder road
Color: yellow
MrRam is on a distinguished road
Unhappy Big Bang front end
Ok kinda have a problem here I just replaced my front shocks and sway bar bushings, and now when I hit a pot hole,rail road tracks, I have a for a lack of a better term bang coming from my driver side front tire hit the same holes with the passenger side and its nice and smooth.
So I just went ahead and replaced the shock thought maybe a bad shock not the case still there could it be from the sway bar? Did I install it wrong
Using skyjacker shocks need help, Any info would help.
2005 ram 1500 4x4 5.7L
Old 04-25-2013, 07:28 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
I know a few guys one here when installing the bislteins, mixed up the order of the washer/nut/and somethin else and it caused this. Double check your install very carefully
Old 04-25-2013, 09:08 AM
LowcountryHemi's Avatar
LowcountryHemi LowcountryHemi is offline
Rep:23
LowcountryHemi is on a distinguished road
My best friend did this exact thing in a Jeep. It's easy to mix up the order, especially if you're working on it late or are tired.
Old 04-27-2013, 10:52 AM
MrRam's Avatar
Color: yellow
Thanks guys it was a late night,I have the week end off and will be looking into this issue, will let you know how it goes
Old 04-27-2013, 10:59 PM
tclark's Avatar
tclark tclark is offline
Vehicle: 2009 Dodge Ram QC
Color: Deepwater Pearl
tclark is on a distinguished road
I installed my leveling kit last weekend and couldn't get the rubber bushing between the washer and control arm back on so I went for a ride to get it to settle and had similar sounds coming from the front end. When I go home I was able to put everything back like it was supposed to be and the noise was gone.
Old 04-27-2013, 11:56 PM
MrRam's Avatar
Color: yellow
Smile
The sleeve that goes into the bottom bushing was abnormal replaced with one from a mother shock and every thing looks good.
shocks, suspension, swaybar
