Old 04-23-2013, 12:19 PM
bknife's Avatar
bknife bknife is offline
Vehicle: 2010 Dodge ram 1500 Big horn
Color: Black Pearl
Rep:49
bknife is on a distinguished road
Yeah i hear you on that..But I am not sure what system is used I am seeing wheel weights on the inside of the tires and one of them seems to have more than the rest and thats the one I am having trouble with..So by the looks of things it might be a bad wheel or tire but I need to get them rebalanced and see whats up.
[SIGPIC] 20x10 -24mm Fuel Throttles w/ 35x12.50R20 Federals, 1.25 RCX body lift, Bilsteins adj. max 2.8, TGC 1 inch rear coil spacer, Spyder smoke LED tail lights, Recon 3rd LED tail light, Bone Collector weather front floor mats and rear window sticker
Old 04-23-2013, 01:08 PM
Keep us posted please
click here --->***Tuner and Muffler Sale*** <---click here
Old 04-25-2013, 09:00 AM
bknife's Avatar
Color: Black Pearl
Rep:49
So I am hoping to have them rebalanced friday and we will see what happens after that!
Old 04-28-2013, 10:46 AM
bknife's Avatar
Color: Black Pearl
Rep:49
So I have them sending me some balancing beads to see if that helps my one wheel stop shaking..he 100% says it will stop we will see!
Old 04-28-2013, 12:30 PM
mattman13 mattman13 is offline
Vehicle: 2012 Ram 1500
Trim Level: slt big horn
Rep:44
mattman13 is on a distinguished road
Makes me wish I had found a used PXR instead of buying a new px8 that offset is awesome and def what I'm going with for rmy next setup
SPONSORED BY: bULLY'S pERFORMANCE
Old 04-28-2013, 07:43 PM
bknife's Avatar
Color: Black Pearl
Rep:49
Thx matt..I love it and I am so glad I couldn't get the -12 and had to go with -24..love the stance bro
Old 04-28-2013, 08:34 PM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
Truck looks sick ! got the same wheels and 37" toyo's ordered for my ram .
Old 04-28-2013, 08:43 PM
ckage83 ckage83 is offline
ckage83 is on a distinguished road
I used to be a shop manager at a tire/garage place. If you are experiencing a shake, is it in your steering wheel or seat?
Steering wheel = front
Seat = rear
Rotate tire front to back to see if the shake moves. If it does rebalance the offending tires. It is perfectly normal for one rim/tire to require more weight than another. No two tires are created equal.
After rebalance. Still shakes? Again, remove the offending rim(s) and tires and spin them on balance machine. Tech should watch or even ride a hand on the tire as it spins to feel if there is a "hop". From time to time we had good luck with dismounting a tire spinning it on the rim for a low point matchup then rebalancing it. This usually required less weight.
Worst case is the rim is out of round. Very rare but does happen. Again, spin the rim by itself. Finally, contact the manufacturer of the tires and request the tire be swapped out.
DOCUMENT EVERYTHING you do before you get to that point.
Let me know if you have any other questions.
Old 04-28-2013, 09:14 PM
So....how did it go?
Old 04-29-2013, 07:06 AM
bknife's Avatar
Color: Black Pearl
Rep:49
Nice 2012 ram I am sure that set up will be sick!..Thank you so much ckage it is in my seat, and I know which wheel it is so waiting on these beads to get here to try that and we will go from there..Still waitn fast hope to have them early this week!
