Old 05-09-2013, 04:05 PM
beast88 beast88 is offline
Vehicle: 2013 Dodge Ram
beast88 is on a distinguished road
wow thats close...i think i might have to move my header up so I can fit in. Im thinking about getting the body lift as well....and i think my great ruim debate is solved with the new kmc rockstars II. They are making a 20X9 -12, perfect for my needs, and plus i wont have the same rockstars as everybody else, at least for now, only bad thing is I will have to wait until augest. Now I will be trying to figure out if I can set my bilsteins to 2.1 and not rub or I will have to go with them set at 2.8 and then think about a rear spacer...decisions decisions
Old 05-09-2013, 04:29 PM
my garage door is only 80'' and i think the 2013's sit a little higher...i might need that inch from the bilstiens and coil spacer
Old 05-10-2013, 08:01 AM
bknife's Avatar
bknife bknife is offline
Vehicle: 2010 Dodge ram 1500 Big horn
Color: Black Pearl
Rep:49
bknife is on a distinguished road
True beast but I bought the bilsteins one for the lift and two for the ride so I wanted to get as much lift as possible with out spending the big money for the suspension lift. IMO go as high as you can because it will look better with the 35s not being so stuffed...Good luck brother!
[SIGPIC] 20x10 -24mm Fuel Throttles w/ 35x12.50R20 Federals, 1.25 RCX body lift, Bilsteins adj. max 2.8, TGC 1 inch rear coil spacer, Spyder smoke LED tail lights, Recon 3rd LED tail light, Bone Collector weather front floor mats and rear window sticker
Old 05-10-2013, 08:02 AM
bknife's Avatar
Color: Black Pearl
Rep:49
I will try and clean up my truck and post some different pics up soon! My lacrosse season is almost over and that takes up my time.
Old 05-10-2013, 01:46 PM
bknife's Avatar
Color: Black Pearl
Rep:49
So I just got the balancing beads in and he said it will take a few miles to get them to work will keep you updated!
Old 05-10-2013, 02:41 PM
Few miles later...and? ......
Old 05-10-2013, 10:38 PM
How much lift will the bilstiens at 2.8 give you? It doesn't seem like there giving you a full 2.8'' from what ive seen online
Old 05-10-2013, 10:40 PM
Its actually 2.75" and once settled you'll drop down to 2.5"-2.6"
Old 05-12-2013, 12:30 AM
bknife's Avatar
Color: Black Pearl
Rep:49
What fast said. Also my beads are in and its much better than it was!
Old 05-12-2013, 12:31 AM
Glad it worked out
