Old 01-11-2014, 11:43 PM
Rogerwa's Avatar
Rogerwa Rogerwa is offline
Vehicle: 2009 Dodge Ram 1500 5.7l Crew
Color: Greystone
Rep:30
Rogerwa is on a distinguished road
Default Experience with Half shaft replacement
Has anyone replaced the half shaft on the drivers side? Mine sounds like it is coming apart and I am going to tackle the replacement. I have done wheel hubs and brakes, struts , ETC on other vehicles so I know my way around this area. Do I have to remove the whole steering knuckle or can i get away with the just the upper ball joint and the tie rod end. Not sure of the clearance.
I know that the service guide recommends pulling the whole knuckle. Just looking for those that have done this and to learn from their experience..
2009 Ram 1500 Big Horn Crew Cab 5.7l Hemi
Twin Cities, MN
Old 01-11-2014, 11:52 PM
hemi4452's Avatar
hemi4452 hemi4452 is offline
Vehicle: 2013 ram crew cab sport
Color: True blue pearl
Rep:69
hemi4452 will become famous soon enough
I have removed the axle on my 03 by upper ball joint and tie rod. It took alot of muscle to pry it out . Not sure if 09 is the same. I had a lot of noise from mine and it wasnt just the axle. I had to remove the Half shaft inside the front differental . Wasnt a big deal. Just had to make a long thin rod to push out a pin inside that held it all together.
Old 01-12-2014, 12:25 AM
Rogerwa's Avatar
Color: Greystone
Rep:30
According to the manual, the inner end should just pry out. Doesn't mention anything about a c-clip or anything. The instruction to pull the hub mentions the separation of the upper joint and the tie rod end and then the knuckle will move outward enough to separate the shaft end from the bearing. I am hoping this is enough to allow the whole shaft to come out.
Twin Cities, MN
Old 01-12-2014, 03:26 AM
I push the skinny pedal
Rep:3277
There are no c-clips that hold anything, however there is one c-clip on the inner side that's just a locator. You don't need to remove the entire steering knuckle, just popping the upper balljoint out will simplify the swap, but it can be done without doing that, it's just a PITA. The steering knuckle and sway bar need to be disconnected.
Kurtis
Old 01-12-2014, 11:10 AM
Rogerwa's Avatar
Color: Greystone
Rep:30
What do you mean about the clip being a locator. Thanks..
Twin Cities, MN
Old 01-12-2014, 02:22 PM
Rep:3277
There is a step spline on the inner joint, mine came with a c-clip that sat between the 2 so you don't impact the larger spline on the small inner one.
Kurtis
Old 01-12-2014, 03:14 PM
hemi4452's Avatar
Rep:69
If your talking about front axle then it will pull out. I was refering to the half shaft inside the front differential. Where the axle slides over ..
Old 01-12-2014, 04:22 PM
Rep:3277
Don't mind me then, I was specifically talking about the axles.
Kurtis
Old 01-12-2014, 09:21 PM
Rogerwa's Avatar
Color: Greystone
Rep:30
Thanks guys for the feedback, but today I lucked out. I jacked up my truck and spun the wheel to hear the noise. I also grabbed the tire and rocked it side to side to ensure it was not the bearing. What did i find?? Loose lug nuts.
I had the tire checked by a garage earlier in the week as it was losing air. Apparently they did not torque the lug nuts.
I thought it was the CV axle as it was making a clicking sound as the wheel turned.
Twin Cities, MN
