Old 04-09-2013, 02:42 PM
Megacraig's Avatar
Megacraig Megacraig is offline
Vehicle: 2013 Dodge Ram 1500
Color: Max Steel
Rep:28
Megacraig is on a distinguished road
Default What other years will work for spacers and rims?
I have a 2013 1500 and want to put some 2"+ spacers on it but cant find anything more than a 1/4" for a 13. Has ram changed the spacing or pattern any from the other 4th gens? Because i have found alot of stuff if i go a few years prior.
Old 04-10-2013, 08:52 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
they shouldn't be any different. bolt pattern is still the same so...you should be able to use any spacer I'd imagine. Just be careful running spacers that big...don't get cheap ones
Old 04-14-2013, 10:07 AM
AsILayDying's Avatar
AsILayDying AsILayDying is offline
Vehicle: 2007 Dodge Ram 1500 SLT 5.7
Trim Level: SLT Big Horn
Color: Burgundy
Rep:45
AsILayDying is on a distinguished road
I would definitely go with HUBCENTRIC spacers.... 2" is fairly big but would look good. Basically look for something that is marked as 5x5.5 or 5x139. Here are a few I found but they are 1.5". The 2" I cant find in Hubcentric.
http://www.ebay.com/itm/4-Dodge-Ram-...#ht_566wt_1399
Old 04-14-2013, 01:32 PM
bmx2day bmx2day is offline
Vehicle: 11 1500 Sport
bmx2day is on a distinguished road
Check out rough country spacers also, their big in the Jeep stuff but same bolt pattern
Old 04-15-2013, 01:32 PM
Megacraig's Avatar
Color: Max Steel
Rep:28
Originally Posted by AsILayDying View Post
I would definitely go with HUBCENTRIC spacers.....
What makes a spacer hub centric? I kind of just assumed they all were centered. I know im gona probably have to pay more than i want for that size but wide stances just look mean. Plus they throw some pretty good mud once they're outside the fenders
Old 04-15-2013, 04:01 PM
Jon3sgte Jon3sgte is offline
Vehicle: 2012 Ram CC
Trim Level: Tradesman
Rep:30
Jon3sgte is on a distinguished road
Some spacers just slide on adding more and more stress to the factory bolts the wider the spacer is. Other spacers bolt up to your factory posts and give you a new set of posts. This is the better way to go. 2" will be alot of spacing and stress on your lug posts. I would recommend a lower offset wheel if at all possible before doing a 2" spacer. Especially if you are going to be mudding and/or putting extra stress on the suspension.
1500, 2013, match, wheel spacers
