Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8 > MDS
MDS Multi Displacement System Discussion
Old 04-05-2013, 02:06 AM
RepentaRAM777 RepentaRAM777 is offline
Vehicle: 2004 Dodge Ram 1500
RepentaRAM777 is on a distinguished road
Default MDS Upgrade?
Is it possible to upgrade the MDS from an 04 Ram 1500 with the MDS from an 09+? Or should I just not bother and leave it alone cause I would like to get at least decent mileage since I'm currently running 13-14mpg and would like to reach 15-16+.
Old 04-05-2013, 03:05 AM
Rep:2625
The first year Ram to have MDS was the 2006
to add it to your '04, you would need a different camshaft, the heads off a '06, the computer, wiring, sensors
You would NEVER see a savings from the conversion
Old 04-05-2013, 07:34 AM
gonefishin776's Avatar
Vehicle: 2007 Dodge Ram 1500
Rep:1900
yeah that wouldn't be worth it at all. Most hate MDS and it really doesn't do chit for gas mileage.
check your air filter
change your spark plugs
check tire pressure
don't drive around with unnecessary weight
keep your foot out of the skinny pedal
all easy things to do to improve/keep your MPG consistent.
Old 04-05-2013, 01:42 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
Ya, honeslty lots of guys with tuners are turning MDS off and getting just as good if not better fuel economy. It will make a difference if you do a ton of highway driving but you won't notice anything in the city. And like the guys above said, with all the work you will have to to do make it work it isn't worth the money. You'd be better off buying a new Ram.
Old 04-06-2013, 06:34 PM
check tire pressure
Yeah I kinda figured in a way, and I've done about all that except for spark plugs and i haven't checked my tire pressure lately…. prob should do that, also would adding an extra 5 pounds of air help? it helped with my old dakota and i would assume it would do the same in the ram
Old 04-06-2013, 06:35 PM
I always wondered why people did that but that just solved my worries there, and I would get a newer one except I inherited this truck (in a way) so Im NEVER getting rid of it and can't afford a new one.
Old 04-07-2013, 02:29 PM
S.C. Express S.C. Express is offline
Vehicle: 2012 Ram Express
Rep:63
S.C. Express will become famous soon enough
I run my tires at 38-40 lbs. of pressure. Rides like crap but gets 1-2 mpg better than running 34-35 like I have always done in the past. Anything you do to decrease rolling resistance will improve fuel economy.
I don't know what oil you use but switch to a full synthetic 5w-20 and I bet you will see a difference in mpg's.
Jones MaxFlow 18" muffler swap, Green Performance drop in air filter..
