United Radio
Old 04-04-2013, 11:26 PM
ElDeDurango77's Avatar
ElDeDurango77 ElDeDurango77 is offline
Vehicle: 2014 Ram R/T
Trim Level: 2wd RCSB
Color: Blue Streak Pearl
ElDeDurango77 is on a distinguished road
Default 2012 ram engine swap???
Does anyone know if you can swap out the 345 to a 426 crate engine? If there is, what else is required in order for it to function properly without any problems?
Old 04-05-2013, 08:20 AM
gusman's Avatar
gusman gusman is offline
Vehicle: 2013 1500 Quad Cab
Color: Black on Black
Rep:47
gusman is on a distinguished road
Anything is possible with enough money. A swap like this, although cool, would be pointless and incredibly expensive.
Old 04-05-2013, 02:52 PM
idefi idefi is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Limited
Rep:26
idefi is on a distinguished road
I just googled the prices, that is crazy expensive!! I would have a hard time putting $15k into a motor on an already powerful truck.
Old 04-05-2013, 03:20 PM
letsjet's Avatar
letsjet letsjet is offline
Vehicle: 2014 Ram 1500 Express 5.7L 4x4
Trim Level: EXPRESS
Color: FLAME RED
Rep:27
letsjet is on a distinguished road
Some Challenger guys have done it for about $18K.
2014 Ram 1500 Express 5.7L Quad Cab 4 X 4 Flame Red
2010 Dodge Challenger R/T Hemi Orange Pearlcoat
2010 Dodge Challenger R/T Classic Furious Fuchsia 6 spd
Old 04-05-2013, 03:47 PM
RAM EM's Avatar
RAM EM RAM EM is offline
Vehicle: 2012 Hemi express quad
Trim Level: ST express
Color: Grey
Rep:195
RAM EM has a spectacular aura aboutRAM EM has a spectacular aura about
You can put a jet turbine in a sedan (seriously) with enough money, time, and tools. But why?
-DS Trinity- Hemifever tuned - 18" Magnaflow - BT catch can - 180 Tstat - 22" SRT10's - 305/45 Nitto 420 - SG 2/4 drop - blacked out heads/tinted tails - dechromed/debadged - 20% tint-
Old 04-05-2013, 03:55 PM
RPM666's Avatar
RPM666 RPM666 is offline
Vehicle: 2012 RAM 1500 LL Limited 4x4
Color: True Blue
Rep:363
RPM666 is just really niceRPM666 is just really niceRPM666 is just really niceRPM666 is just really nice
If the 426 is the 6.4L you should search for a 6.4L stroker kit. They're probably $3500.
S&B CAI // Flowmaster 50 Series HD // Bilstein 5100's @ 2.8" // Lockpick V5 // Hypertech Interceptor // Cabin filter mod // BP Polished Catch Can // TonnoPro LoRoll Cover // 4 Digit Combo Console Vault // Escort 8500 X50 Blue // GumCreek Vehicle Holster
Old 04-05-2013, 03:58 PM
gusman's Avatar
Rep:47
I thought 6.4 was 392
Old 04-05-2013, 04:19 PM
hydrex's Avatar
hydrex hydrex is offline
Vehicle: 2005 QC 4X4 HEMI RAM
Trim Level: Thunder Road
Rep:418
hydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nicehydrex is just really nice
A 5.7 based 392 is the way to go. Been done several times.
Inertia Spartan Plus cam, Circle D 3,000 rpm stall converter,Sonnax line pressure booster, MagHytec 68RE pan,and differential cover, Vararam, JBA's with cut outs, Rancho 9000's,3:92's, extra rear leaf.Line-X Bedliner, 210,000 miles To Hell and back. 14.2/96 mph NEDW
Old 04-05-2013, 04:31 PM
browndawg's Avatar
browndawg browndawg is offline
Vehicle: 2012 ram 1500 4x4 express rcsb
Color: true blue pearl
Rep:101
browndawg will become famous soon enoughbrowndawg will become famous soon enough
im sorry but it says ur 20 yrs old, just hit the lottery or something just curious cause i didnt have a pot to piss in when i was 20 and hell yes im nosey just in case u invented a money machine or something
Old 04-05-2013, 04:38 PM
RadioFlyer's Avatar
RadioFlyer RadioFlyer is offline
Rep:146
RadioFlyer will become famous soon enoughRadioFlyer will become famous soon enough
Yes you can, but with lots of modifications. The timing cover and alternater/airconditioning brackets are different and the 6.1 pulleys don't allign with the 5.7 pulleys. It would be easier to just go with a 5.7 stroker motor. For instance I beleive you can turn a 5.7 into a 3.92 with a 4.050" crankshaft or a 6.1 into a 426 with the same. I myself wouldn't go over a 4" stroke on these hemis because of the skirting (lower piston wall) coming out of the block too far. It can be done and they do it with confidence but the wear on the pistons and walls would be greater than in 4" and lower. However and I don't know which ones do if they do, they can raise the wrist pins up by .050 to compensate for the skirting coming out too far. So for instance Manley, Scat, Bryant, Callies/Compstar all make this 4.050 crank and stand by it. Compstar makes a 4" but I'm not sure about any of the others. I've heard people going so far with strokes that they have to move the wrist pin into the ring area of the piston. I don't see how they get away with that but they do. Best alterative to all of this if one could afford it is to go with a 6.1 aluminum block but good luck trying to find a stout 4" cs for it. There are so many 4.050 cranks on the shelves for these because of the cast iron blocks but not enough 4" for the aluminum blocks, good luck.
2012, 5.7, 7.0, express, ram
