Old 02-22-2014, 07:19 PM
Casper13 Casper13 is offline
Vehicle: 2013 Ram
Trim Level: Laramie Longhorn
Rep:46
Casper13 is on a distinguished road
My driver side map light would not work so I searched the forum and found this thread.
K9ENDY - that is an excellent write up. Thank You.
stevev201 - your ideal of reusing the chrome strips with screws works perfectly.
I finished changing the map lights to blue and put everything back together and it looks like a factory install. I was going to leave my like K9 did with blue up front and leave the dome light alone. Well after awhile I could not just leave the dome light alone but on some Ram models the dome light is a smd led. I am going to be brave and take that sucker apart and see how to change the dome light to blue.
Old 02-24-2014, 07:26 PM
vyper340 vyper340 is offline
Vehicle: 2014 Ram 1550 Longhorn Limited
Trim Level: Longhorn Limited
vyper340 is on a distinguished road
Anyone know how to replace the bulb in the upper glove box?
Old 06-01-2014, 01:13 PM
jack4656's Avatar
jack4656 jack4656 is offline
Vehicle: 2013 RAM 1500 Laramie Crew Cab
Trim Level: Laramie W/Flare
Color: Mineral Gray w/Metalic Silver Trim
jack4656 is on a distinguished road
Originally Posted by stevev201 View Post
Hi to all, new to the forum, but have owned many Rams. If I can add to the end of this post regarding the front map lights and making them LED. If you follow the above post which is great and get to pulling the overhead light set down so you can see what is being talked about, there just afew more steps to adding the LEDs and keeping it stock looking. The 3 small plastic mushroom looking things that hold the trim thats mentioned just need to be cut off flush with a sharp knife or razor blade. After that both the trim and then the bulb under it will come right off. Then simply install your new LED bulb as shown. In order to reattach the trim, take a very small drill bit like a 1/16th and carefully drill a hole down the center of each of the plastic studs that remained after you cut off the tops and removed the trim and bulb panel. Then you just have to locate 3 very small sheet metal style screws (I used RC palne trim screws since they are small) and carefully screw them back in , thru the trim pc. holes to reattach to the 3 post. Be careful so you dont split the plastic post. Did mine, they look stock, are tight and work way better than stock. Hope this helps those with the 2013s and newer.
Steve201; I would like to thank you for your POST. I have been reading old threads trying to find information on intensifying my interior lights. Your POST was very informative.
____ Click HERE to see Photos of Jacks Toy.____
TruXedo Lo Pro QT Tonneau Cover, Putco Crossrail Side Bed Rails, Two (2) DeeZee tailgate assist, K&N CAI, Husky Liners X-act Contour Floor Liners, Husky Liners Mud Guards, DashMat Ultimat Dashboard Cover, AVS Windflector, AVS Bugflector II, WeatherTech Side Window Deflector, Cabin Air Filter, DRL Mod.
Old 07-11-2014, 12:00 AM
Morloki's Avatar
Morloki Morloki is offline
Vehicle: 2013 Sport
Trim Level: Sport, CC
Color: Copperhead Pearl
Morloki is on a distinguished road
I was wondering if anyone can tell me how to get these two covers off. I seem to be having some issue with the first one for sure. Cant seem to figure out how it comes off.
Thanks
Old 07-29-2014, 05:45 PM
Sstagg2112 Sstagg2112 is offline
Vehicle: 2013 dodge ram 1500
Color: Grey
Sstagg2112 is on a distinguished road
Definitely no need to mess with the chrome. Just get a flat head and carefully work the OEM light out and you can just pop in the LED.
Old 08-05-2014, 03:53 AM
flames57 flames57 is offline
Vehicle: 2014 Dodge Ram Laramie Longho
flames57 is on a distinguished road
Can you change the color of these lights from any control that is OEM?
Old 08-10-2014, 09:34 PM
AnthonyK6 AnthonyK6 is offline
Vehicle: 2013 Dodge Ram 1500 Sport
Color: Blue
AnthonyK6 is on a distinguished road
How do you work around the chrome? based on the pictures there is the chrome plate with a little plastic square for the light to go through?
Old 10-07-2014, 02:10 PM
RoRo10 RoRo10 is offline
Vehicle: Ram 2014
Rep:13
RoRo10 is on a distinguished road
^^^ i'm curious as well. I have a 2014 and I put white led lights in all my cars (I find it gives the interior a richer and modern look.)
I'm coming across this exact problem. I pop off the plastic piece from the lights, but then the chrome piece is in the way. has anyone managed to change their 2013+ lights with the chrome housing to leds? I don't want to do just the front section and not the back.
PS. OP how did you manage to the chrome pieces out?
2013, dodge, interior, lighting, ram
