Old 11-14-2013, 08:28 PM
stevev201 stevev201 is offline
Vehicle: 2013 Ram 1500 Quad Cab
stevev201 is on a distinguished road
Cool Ram Interior map lights
Hi to all, new to the forum, but have owned many Rams. If I can add to the end of this post regarding the front map lights and making them LED. If you follow the above post which is great and get to pulling the overhead light set down so you can see what is being talked about, there just afew more steps to adding the LEDs and keeping it stock looking. The 3 small plastic mushroom looking things that hold the trim thats mentioned just need to be cut off flush with a sharp knife or razor blade. After that both the trim and then the bulb under it will come right off. Then simply install your new LED bulb as shown. In order to reattach the trim, take a very small drill bit like a 1/16th and carefully drill a hole down the center of each of the plastic studs that remained after you cut off the tops and removed the trim and bulb panel. Then you just have to locate 3 very small sheet metal style screws (I used RC palne trim screws since they are small) and carefully screw them back in , thru the trim pc. holes to reattach to the 3 post. Be careful so you dont split the plastic post. Did mine, they look stock, are tight and work way better than stock. Hope this helps those with the 2013s and newer.
Old 11-15-2013, 01:52 AM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
I had one of the LEDs quit working in my map lights. Dealer has to replace complete overhead console to replace the non-working LED!
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
Old 11-15-2013, 11:51 AM
Breathing Borla's Avatar
Breathing Borla Breathing Borla is offline
Vehicle: 2013 Ram 1500 Sport 4x4
Color: Maximum Steel
Rep:89
Breathing Borla will become famous soon enough
i guess I'm confused but all the interior lighting is already LED, why would you want to change it?
I thought it was really really good stock
2013 Ram Sport Crew 4x4, 5.7, 8-speed, 3.92, LSD, Borla
2010 LTD Tundra DC, 4x4 RW Wheels 33" Cooper Maxx
2001 tundra, 2000 tundra
1995.5 Tacoma, 1997 Tacoma, 1998 Tacoma
Old 11-15-2013, 10:07 PM
Omac's Avatar
Omac Omac is offline
Vehicle: 2013 RAM 1500
Rep:29
Omac is on a distinguished road
I was thinking the same thing. All of mine are LED and the doors have blue LEDs in them awesome look.
Mopar Hood Deflector, Mopar Mud Flaps Front/Rear, Fire/Ice Mud Flap LEDs, Tonno Bed Cover, Mopar Bed Mat, Mopar Tailgate Liner,Window Tint, Husky WeatherBeater Floor Liner Front/Rear, Mopar Chrome Gas Door
Old 11-16-2013, 10:48 PM
Of course you are right, they are already LED. However adding the new LED bulbs as I did, increased the light output and gave them the blueish look which many of us like. The stock LEDs are set to look closer to a standard bulb color. Sort of like changing out your stock halogen bulbs to HID. More light. As I said above, if you want to upgrade the fronts, follow the post and just finish it as I did and you will be a happy camper and the trim pc. will look totally stock Or leave as is.Yiur choice for sure..
Old 11-17-2013, 06:52 PM
phobos512's Avatar
phobos512 phobos512 is offline
Vehicle: 2013 Ram 2500 4x4 CCSB CTD
Rep:6
phobos512 is an unknown quantity at this point
You realize that human beings are most sensitive to blue lights and this will absolutely wreck your night vision when you turn them on, right? Better off with yellow/red lights in a vehicle for night time use...Sure they look cool, but functionality and safety...To each their own
Matt || 2013 2500 Laramie || CCSB 4x4 CTD || Maximum Steel || Nitto Terra Grapplers 305/70-17s
Old 01-11-2014, 10:37 AM
NY Ram 86's Avatar
NY Ram 86 NY Ram 86 is offline
Vehicle: 2013 Dodge Ram 1500
Trim Level: Tradesman Express
Rep:19
NY Ram 86 is on a distinguished road
This may seem like a dumb question, however I am new to modifying anything in a vehicle. I have a 2013 Ram 1500 Tradesman Express and I do not have the overhead console. All I have are the two lights that I need to press to turn on and the other small light that turns on when my lights and dash board lights are on. I love the look of the blue lights that you guys have posted; is there a way for me to change out this small light and install a blue LED light? Also, has anyone tried adding floor board lights?
Old 01-11-2014, 10:56 AM
NY Ram 86's Avatar
Rep:19
I put this in here since it is specific to the 2013 Ram. I had previously started toying with the interior lights but when I realized there was a different configuration for this year, I backed off and asked.
I had posted a question about replacing the LED's in the exterior and interior lighting section of the forum and had not received a reply (that worked) after bumping it a couple times.
Unfortunately, the book for the 2013 Rams has not been updated with current information. It's a nice day so I decided to have another look. Here is what I found. You may not like it.
The front map light bulbs are pretty strange looking and they are behind chrome painted plastic pieces. To get the bulb out you have to remove the chrome pieces and by the looks of it, there is no way to get them back on.
This pic is a new light on the left and the chrome plastic piece still affixed on the right.
The bulbs that I had, which thankfully worked are part number 921-B9 (wedge base, 9 LED bulb) from superbrightleds.com. There is no issue with them not turning off when they are supposed to so no resistor should be needed.
Hope this helps.
I really like what you did here with the interior lights and I really like the look of the blue. Is this something that a novice might be able to accomplish? Also, the small 'courtesy light' (as I call it) that is centered between the two lights, which stays on when the dash is turned on, can that be changed out as well for a blue light?
Old 01-11-2014, 11:03 AM
DTOM DTOM is offline
Vehicle: 2013 1500 cc limited
Trim Level: Limited
DTOM is on a distinguished road
What is the trick to getting the headliner upper front console out? I have a rattle in there and would like to take it apart without breaking anything. Thanks in advance.
Old 02-14-2014, 08:24 PM
ram10000 ram10000 is offline
Vehicle: 2014 Dodge ram
Trim Level: outdoorsman
ram10000 is on a distinguished road
that little light behind the rear window switch, can you turn that off?
2013, dodge, interior, lighting, ram
