View Poll Results: Help choosing rims
Pro comp 8180 20x9 offset 0 backspace 5in 3 23.08%
fuel hostage 20x9 offset -12 bore 87.10 4 30.77%
fuel hostage 20x9 offset 1 bore 87.10 1 7.69%
fuel hostage 20x9 offset 20 bore 87.10 0 0%
fuel boost 20x9 offset -12 0 0%
fuel boost 20x9 offset 1 3 23.08%
fuel boost 20x9 offset 20 0 0%
moto metal m0962 20x9 offset 0 backspace 5in 2 15.38%
Voters: 13. You may not vote on this poll
Old 03-16-2013, 08:46 PM
Ramkt7 Ramkt7 is offline
Vehicle: 2012 RAM 1500
Trim Level: Bighorn
Color: Cherry red
Rep:21
Ramkt7 is on a distinguished road
Default Need help picking wheels and tires for my 2012 cherry red ram
Hello,
I'm seeking your help in picking wheels and tires for my 2012 ram 4x4.
I'm going to run the bilstein struts up front to level it at the 2.1 inch setting.
The tires I want to go with are nitto trail grappler m/t.
People have recommended me to go with the 295/60/20, but someone said that a 295/65/20 and was wondering if this would fit as they said it is the same width just taller. So what tire would you choose i want to run no spacers and have no cutting or modifications done?
Here's my truck
The first rim I'm interested in, is by pro comp its the model 8180
its Gloss black with machining, 20x9, 0 offset, 5 inch backspacing
This one is the fuel hostage d531 its going to be matte black
they make it in 3 different offsets its going to also be 20x9 and bore is 87.10
The offsets are -12, 1, and 20 if would choose this rim what offset? also would the 87.10 bore work?
This one is also by fuel its the boost d534 also in 20x9 but has different offsets and bores to pick from, sorry I'm new to this and don't know what bore will fit
it comes in offset 1 and 20 at a bore of 110.30, and also comes with a 87.10 bore with offsets -12, 1, and 20, and one bore at 108.00 at -12 offset? which bore works with are truck?
and the last one is a moto metal M0962 Gloss black also 20x9 with offset at 0 and backspace 5 inch
so im asking which tire size would you pick as I don't want to have to do any modification or use spacers? and which rim and if they have one or more offset or bore which one would you choose?
once again sorry for it being so long, I'm new to this and haven't seen any of these rims in person so I'm hope you guys can help! or if you have a rim that you would recommend that looks good let me know!
Thank you!!
Old 03-16-2013, 08:58 PM
Ahays63's Avatar
Ahays63 Ahays63 is offline
Vehicle: 2014 Dodge Ram
Trim Level: sport
Rep:267
Ahays63 is a jewel in the roughAhays63 is a jewel in the roughAhays63 is a jewel in the rough
Originally Posted by Ramkt7 View Post
Hello,
Here's my truck
Thank you!!
i just got the fuel dunes 20X9 +1mm offset and trail grapplers in 295/65R20 they will fit with no rubbing i had no problems with mine i alse did the bilstein leveling shocks just this morning
awww no mods yet due to restarting on a new pick up
Old 03-16-2013, 08:59 PM
Ahays63's Avatar
Trim Level: sport
Rep:267
o and i forgot to tell you i had about 1/2" of space to spare as far as rubbing goes...very happy with the results!
Old 03-16-2013, 09:03 PM
Trim Level: Bighorn
Color: Cherry red
Rep:21
thanks i just wanted to make sure they fit because it about another inch of height as i wanted to go with those. Also what setting do you have the bilstein struts at?
And nice looking truck i cant wait to decide on some rims lol
Old 03-16-2013, 09:09 PM
Ahays63's Avatar
Trim Level: sport
Rep:267
i went with 2.8(maxed setting) and they measure exactly the same in all four corners in the fender wells so it sits perfectly level
Old 03-16-2013, 09:16 PM
Trim Level: Bighorn
Color: Cherry red
Rep:21
you think ill still be fine with a 295/65/20 tire at the 2.1 setting
Thanks
Old 03-16-2013, 09:17 PM
Ahays63's Avatar
Trim Level: sport
Rep:267
i would think so the 2.1 setting isnt that much lower from what i could tell when i looked at them and i had a half in or better to spare
Old 03-16-2013, 09:21 PM
Trim Level: Bighorn
Color: Cherry red
Rep:21
k thank you for the help!!
Old 03-18-2013, 11:04 PM
Trim Level: Bighorn
Color: Cherry red
Rep:21
need your opinion guys!
Thanks
Old 03-19-2013, 07:09 AM
Trim Level: Bighorn
Color: Cherry red
Rep:21
hey guys im leaning towards the fuel hostage wheels with the 295/65/20 nitto trail grappler tires i was looking at getting the 1 offset, also i dont know if the bore size is 87.1 or 78.1 does that matter?
and you think there is any way to run the 35x12.5x20 with the bilstein struts with the fuel hostage rims at a 1 offset, also what is the difference for in the -12 offset?
so would you guys recommend the hostages in 0 offset or -12 offset and im just going to have the bilstein set at 2.1 and the tires are going to be 295/65/20 i hope they will fit with no rubbing
Thanks for the help guys!
