Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Heating & Cooling
Heating & Cooling 4th Gen Dodge Ram Heating & Cooling Problems and Questions.
Old 03-13-2013, 08:08 PM
Rferreira91 Rferreira91 is offline
Vehicle: 2005 dodge ram 1500
Trim Level: Base
Rferreira91 is on a distinguished road
Default Fan constantly runs help!!! Lol
When i hit the gas the fan runs equal to the rpms. Not sure if this is a dodge thing or if i need a new fan clutch. Any ideas would be great! Thanks
Old 03-14-2013, 04:29 PM
Divi Divi is offline
Vehicle: 2011 Ram 1500 Crew cab
Trim Level: Sport, loaded
Color: Obsidian Black Pearl
Rep:112
Divi will become famous soon enoughDivi will become famous soon enough
can you spin the fan with the engine off? if not your clutch is frozen on your fan.
2011 Ram 1500 crew OBP, Airraid Cold air, Bestop roll up, Lockpick v5, custom carbon interior trim.
Old 03-17-2013, 08:49 PM
Trim Level: Base
Yea i can. It must be how it runs then. Sometimes it sounds normal but then theres times were it sounds like the fan seems like its running when it shouldnt
Old 03-19-2013, 11:04 AM
Rep:112
well its a engine mounted fan its going to turn when the engine is on.
Old 03-21-2013, 08:27 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
Not sure but your fan should be thermostatically controlled, the clutch shouldn't engage the fan until you reach a higher temperature, it will free wheel slowly while your engine is running but it shouldn't spin the same RPM as the engine until the thermostat tells it to, I would check that out.
clutch, fan, heat, noise
