Old 03-08-2013, 03:42 PM
Yo Nadz Yo Nadz is offline
Vehicle: 2013 Ram 1500 Sport Crew Cab
Trim Level: Sport Crew Cab
Color: Snow White
Rep:160
Yo Nadz has a spectacular aura aboutYo Nadz has a spectacular aura about
Exclamation To those of you who have used VHT Nite Shades, PLEASE HELP!!!
Got busy and tinted my tails today. One problem, they're not shiny!!! =)
Process
-Removed lights
-Wetsanded with a dot of dish soap and 2000 grit
-Cleaned with alcohol and let air dry
-2 coats of VHT, 5 mins between each coat
-45 mins dry time
-Wetsanded with dot of dish soap and 2000 grit
-4 coats of clear, 5 mins between each coat
-1 hour dry time
Lights looked perfect at this point, but hand some orange peel. After the hour dry time I wet sanded them again, then used Mequires Ultimate Compound, and hand buffed.
They looked like crap after that. Still all foggy and full looking, so I sanded a little more and re-cleared them. They are drying now.
What did I do wrong?? Why didn't they buff out shiney??
Did I wet sand the clear too soon maybe? Any help is appreciated!!!
Yo Nadz STOMPER Build Thread ~> http://www.ramforumz.com/showthread.php?t=135821
Lifted & Ignorant 2013 Sport Crew
Proud member of IAFF LOCAL 2665
Old 03-08-2013, 04:36 PM
Gecko's Avatar
Gecko Gecko is online now
Vehicle: 2004 Quad Cab
Trim Level: SLT 4x4
Rep:221
Gecko has a spectacular aura aboutGecko has a spectacular aura aboutGecko has a spectacular aura about
Make sure you rub really hard with the compound at the end. Also You may want to try an electric hand buffer since you will be able to apply more pressure with that and they generally just work better than doing it by hand.
I did the method you did up top with the exception of wetsanding before the clear coat and mine came out fine. I guess you could say they aren't as shiny as glass but they still had a nice finish to them.
Supercharged, cammed, other things too!
Old 03-08-2013, 08:31 PM
Canadian Hemi Pride's Avatar
IDFWY
Vehicle: 2008 Dodge Ram 1500
Trim Level: SXT 4x4
Color: Silver/ Black
Rep:2802
I Just did mine and honestly all I did was clean with AC/ delco window cleaner (has alcohol in it), wiped it dry... did like 2/3 times... dried it all... and sprayed it on... only doing 1 coat.. and looks real good.
Tow mirrors up for the haters
Old 03-08-2013, 08:40 PM
TimW's Avatar
TimW TimW is offline
Vehicle: 2012 Dodge Ram
Trim Level: sport
Rep:161
Process
-Removed lights
-45 mins dry time
-1 hour dry time
When I did my nephews, I'd did everything you did but let them dry over night, 1 hour is not very long for the clear to fully dry, his turned out great. I would just let the clear dry longer
Old 03-08-2013, 08:43 PM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
ya let then dry longer man 1 hour is not enough just let then dry longer then wet sand again and buff them like its your prom date
if you have a electric buffer that works way better
Old 03-08-2013, 08:46 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
pair i did 3 weeks ago
Old 03-15-2013, 01:55 AM
K9ENDY's Avatar
K9ENDY K9ENDY is offline
Vehicle: 2013 Dodge Ram CC
Rep:175
Process
-Removed lights
-45 mins dry time
-1 hour dry time
Well, how'd it turn out? I'm right in the middle of doing mine right now.
Old 11-09-2013, 11:59 AM
Scotian Pride's Avatar
Scotian Pride Scotian Pride is offline
Vehicle: 2013 Dodge Ram 1500
Rep:32
Scotian Pride is on a distinguished road
Does anybody have any pix of how they turned out on their truck? I wanna do this to mine cause I've only found one set of after market lights with a dark red lens and I personally think they look like shit (I'd sooner keep the stock look but darken the lights up. I think it looks cleaner then the aftermarkets) lol. I just wanna make mine so you can still see the red. I figured it'd look good with the mineral grey
Old 11-09-2013, 01:50 PM
IDFWY
Trim Level: SXT 4x4
Rep:2802
Tons of people have used nightshades on their trucks.
Honestly the best picture I currently have. If you would want to see a better picture, send me a message or post a message on my wall and I will take one.
Old 11-10-2013, 04:38 PM
Thebestestdrummer's Avatar
Vehicle: 2001 Dodge Ram Sport
Rep:529
So this is kindaa off topic, but it also goes hand in hand.
I noticed Candian Hemi Pride has a LED bar.. I also know that if someone tints their tail lights too dark, it becomes more so illegal DEPENDING on how dark you go.. But I'm curious, is it NOT illeagal at all when you still CLEARLY have a fully visible brake light, and turn signals? As in an LED bar with turn signals?
Green Interior LEDs
