Old 03-06-2013, 06:26 PM
DaeDae75 DaeDae75 is offline
Vehicle: 2010 dodge ram
Trim Level: Slt TRX
Color: Black.grey
DaeDae75 is on a distinguished road
Default Hid kit help please!!!
I am going to purchase a dull hid kit for my truck fogs, lows, and higs.do I need to purshase a relay harness for any of the kits or will they work fine and if I need one would it bbe for highs, lows, or fogs????
Old 03-06-2013, 06:33 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
As long as you get the right kit it should all be plug and play. Where are you ordering it from? Retro-shop is a good choice if you haven't chosen yet.
Old 03-06-2013, 07:03 PM
Trim Level: Slt TRX
Color: Black.grey
Its a g4 kit 6000k it says it dosent include a relay harness ifs sold separately but I don't know if my truck needs one its a 2010 trx4 hemi single cab
Old 03-06-2013, 07:15 PM
Rep:2026
You don't need a relay harness to run them. There should be a harness to go from your stock headlight plug in to the ballast, and then from the ballast to the HID bulb included in the kit.
Old 03-06-2013, 07:33 PM
Trim Level: Slt TRX
Color: Black.grey
Ok, I just seen where people were talking about kits not working without a relay harness and the highs not working but I can get a harness kit for 10$ if I have that problem but thanks for the help man I've been searching the web like crazy for answers
Old 03-08-2013, 05:57 PM
lbram81's Avatar
lbram81 lbram81 is offline
Vehicle: 2013
Rep:99
lbram81 will become famous soon enough
I recently called around for pricing for HID's for my truck. I was told by many places that if you are not buying a "top of the line" set such as Phillips, you WILL need a relay to avoid the flickering problem Chryslers are known for.
Real question is: Does Ram Quality Control Personnel really exist???
Old 03-08-2013, 06:06 PM
Rep:2026
A resistor is what avoids the flickering, not necessarily the relay.... lots of kits that are specific for the Rams have the resistor build into the ballast. But it all depends on where you're getting it from.
Old 03-10-2013, 11:32 PM
RyanJM's Avatar
RyanJM RyanJM is offline
Vehicle: 2014 Ram 1500
Trim Level: Express RC
Color: Black Express Package
Rep:67
To get it to work without the flickering you can get the ddm plug in errrr cancel boxes they worked great on my 09. The hid kit itself doesn't matter with those. Or you can get the newer style canbus hid kits that are made for these vehicles and from what I have seen they work good. I plan on trying a set in my 13.
Old 03-13-2013, 03:47 AM
Trim Level: Slt TRX
Color: Black.grey
ok i need a relay kit for highs and lows cause all they do is flicker then go off
hid, installation, lights
