Old 07-08-2013, 12:08 PM
toober's Avatar
toober toober is offline
Trim Level: Tradesman
Rep:26
toober is on a distinguished road
Originally Posted by mcritchie View Post
Hey guys and gals,
I have a 2013 ram sport with the 8.4an system. I just noticed that when i exit the truck and lock the doors the radio and the instrument cluster lights won't go out. I am aware that there is an "engine off" section among the setting where you can change the time before the headlights and radio turn off after the engine is shut down. My settings are at 45 seconds for the radio and 30 for the headlights (or vise versa). Anyway, have any of you guys had this problem? any ideas what the problem could be? Also, is there battery rundown protection on the truck?
Originally Posted by dubstalon View Post
After 16 days in the shop, I finally have my truck back. The dealer replaced the gauge cluster on Wednesday and everything seems to be working so far. So it has a new BCM, radio and gauge cluster now.
So have you found the problem to be fixed now? Were they able to pinpoint which item was at fault of the three (bcm, gauge cluster, radio)? I'm taking my truck in soon for the same problem.
Old 08-14-2013, 12:11 AM
dubstalon dubstalon is offline
Vehicle: 2013 RAM 1500
Color: Mineral gray
dubstalon is on a distinguished road
Yes my radio problem is fixed. After they installed a new gauge cluster the radio issue is finally fixed. Now if they could get the thing to stop shaking between 65-75 mph.
Old 10-14-2013, 12:22 PM
metis motors metis motors is offline
Vehicle: 2013 Ram 1500 SLT
metis motors is on a distinguished road
Well yesterday was the day that my radio and dash lights would not go off. so we shall see what my dealership has to say about this tomorrow cause in Canada today is a holiday. also my key has not wanted to come out sometimes and my transmission has stayed in 7th gear for no reason. very interesting. at least I will not be talking to the dealership uninformed. also I unhooked the battery last night when I got home cause the lights were on all day. so hopefully dodge has a cure for these issues.
Old 10-15-2013, 04:43 PM
biesek2006 biesek2006 is offline
Vehicle: 2013 Ram
Color: Maximum Steel
biesek2006 is on a distinguished road
I haven't had any trouble since they updated my Body Control Module I have an Express with the basic radio
Old 10-25-2013, 11:47 PM
Well I took my truck to dodge today for that dash radio problem. and they did an update that failed the second time I shut the truck off so I took it back since I had not left the city yet and they found a brand new update out just this week and apparently my truck was the first one to get it. and so far so good. but they said that when or if this fails... out with the radio and dash. and by the way I told them what I had learned on this site and they kinda played innocent , but all in all so far so good. I should have asked them about that bad smell in the cab.
Old 11-23-2013, 12:03 AM
White1 White1 is offline
Vehicle: 2013 Dodge Ram
Trim Level: Longhorn
White1 is on a distinguished road
Default Dash lights
This happened to me a few days back. Cluster lights stayed on and the battery went dead... At least nothing inside the truck would power up. I didn't check the voltage, so I am not sure if it was dead or the battery protection feature was activated. I charged the battery as the hood light was very dim, and I still could not get any power inside the truck at all (hood light was the only thing that had power). Disconnected the battery neg terminal to reset. When I reconnected the battery the alarm went off till I hit the unlock button on the key fob. Anyway, all ok again, for now at least, but a bit disappointing for a Longhorn with 4000 kms on it. Hopefully just a glitch. I added wrench for the battery terminal to the emergency kit and a note to self to check the cluster lights when I lock it up..
Old 11-23-2013, 12:37 AM
Explorer Rob's Avatar
Explorer Rob Explorer Rob is offline
Vehicle: 2013 Ram 1500 4x4
Trim Level: Laramie Longhorn
Color: Black Gold / White Gold
Rep:264
Explorer Rob is a jewel in the roughExplorer Rob is a jewel in the roughExplorer Rob is a jewel in the rough
What software version is your radio at? The earlier versions had that issue. If you don't have the latest version, try going to the Uconnect website to download the latest version. If you are uncomfortable doing it, your dealer will do it under warranty.
Old 11-26-2013, 01:14 AM
boomer135 boomer135 is offline
Vehicle: 2013 Ram
Trim Level: 4X4 CC Sport
Rep:39
boomer135 is on a distinguished road
I am another one bit by this bug, just 3 days ago battery was dead. I charged the battery and dead again in the morning. Noticed on the 3rd recharge the Evic would stay illuminated, not shutting off.
I disconnected the ground so the battery wouldn't drain, and took it to the dealer this morning.
They preformed all the software updates, and the recalls. EVIC now shuts down and they also tested for any battery drain, when vehicle is off. So far so good… Problem fixed for now.
MODS: PE Full Metal Jackrabbit, BT Catch can, Magnaflow 18", Vararam, Bullydog Hemi Tuner, Zone 1.5 BL, Bilstein 5100's @2.8, TG 1.5 rear coil Spacers, Fuel 20x10 -12OS, Toyo OC MT 315/60R20, Painted BW Pocket Flares http://www.ramforumz.com/showthread....88#post1344588
Old 12-06-2013, 10:54 AM
Have any of you noticed that when you got your radio fixed that the volume was reduced? cause when I bought my truck I was looking at a 300 first and that car was beautiful. and one of the reasons that I chose the truck was the stereo, the truck would do at 22 what the car would do wide open. now I notice that I have to have the stereo at 29 and the base is no longer there, It is that noticeable ! Before the stereo was thick and rich now its weak and thin. I HATE IT!
Old 01-12-2014, 12:00 PM
Razzaa Razzaa is offline
Vehicle: 2013 1500 Sport
Razzaa is on a distinguished road
Currently having this issue. Last time i took it in they updated the software. The update fixed it for 2 weeks. Now it is sitting outside and wont start. Getting annoying to say the least.
2013, battery, lights, ram, sport
