Old 03-02-2013, 08:05 PM
mcritchie mcritchie is offline
Vehicle: 2013 Ram Sport
Trim Level: Sort
Color: Maximum steel metallic
mcritchie is on a distinguished road
Default 13 ram sport dash lights and radio won't turn off
Hey guys and gals,
I have a 2013 ram sport with the 8.4an system. I just noticed that when i exit the truck and lock the doors the radio and the instrument cluster lights won't go out. I am aware that there is an "engine off" section among the setting where you can change the time before the headlights and radio turn off after the engine is shut down. My settings are at 45 seconds for the radio and 30 for the headlights (or vise versa). Anyway, have any of you guys had this problem? any ideas what the problem could be? Also, is there battery rundown protection on the truck?
Old 03-02-2013, 08:28 PM
smokey988's Avatar
smokey988 smokey988 is offline
Vehicle: 2013 Ram Laramie CC 4X4
Trim Level: Laramie CC 4X4
Color: Maximum Steel Metallic
smokey988 is on a distinguished road
Yes the Ram comes standard with (IBS) Intelligent Battery Sensor.
The intelligent battery sensor technology is used to continually measure the flow of current into and out of the battery. If the battery is running low, the system compensates by systematically shutting off onboard electrical systems to help prevent a customer from being stranded due to a low or depleted battery.
Old 03-03-2013, 09:56 AM
Nemmisis1 Nemmisis1 is offline
Vehicle: 2013 Ram 1500 sport
Color: BLACK
Rep:51
Nemmisis1 will become famous soon enough
try to lock your car ans look through the window and see if it shuts off after a few secs. my wifes vw cc does that it drives me nuts makes me think i left the key in the ignition...there is also a power button on the radio hit that before you shut off your motor and then see what happens. ... i also have a 13
Old 03-03-2013, 02:48 PM
Trim Level: Sort
I left the truck sitting overnight and when i checked on it this morning the instrument cluster lights and radio are still on. I got it to start (just barley). Looks like its another trip to the dealer for me. No one else has ever had this problem?!
Old 03-03-2013, 03:46 PM
Stump3r's Avatar
Stump3r Stump3r is offline
Rep:1266
Being these trucks are all software driven it could be as simple as the truck needing a re-boot. Pull your negative battery cable off and let the truck sit for 20 minutes to a half hour. Re-attach the cable and see what she does then. If that doesn't do the trick, get her to the dealer. Could be a simple software flash to correct it.
Big Red my old 2011 Sport
Old 03-03-2013, 06:23 PM
Trim Level: Sort
Good idea! I'll post the results!
Old 04-08-2013, 12:05 AM
k1hanks k1hanks is offline
Color: Copperhead Pearl
k1hanks is on a distinguished road
Having same problem. Instrument lights won't turn off. Drove it yesterday and this morning the battery was so low the radio didn't work. Same problem now so I guess it gets another jump start tomorrow morning.
Old 04-08-2013, 03:34 AM
Rep:2620
with all the Rams built since 2009 & maybe a bit older ones
the alternator will never fully charge your battery
you will need to put it on a charger for a few hours to get the battery fully charged & after it is, the alternator will keep the battery charged at the normal rate
for some reason the Internal Regulator is set to work that way, its something a Dodge Tech can explain better
Old 04-08-2013, 10:48 AM
How does the alternator not fully charging the battery help with the dash lights not turning off?
Old 04-08-2013, 11:05 AM
gage0724's Avatar
gage0724 gage0724 is offline
Vehicle: 2013 Dodge Ram 1500
Rep:12
gage0724 is on a distinguished road
This is the exact problem I am apparently having too. '13 1500 CC Sport. Truck is at the dealer now getting worked on.
2013, battery, lights, ram, sport
