Old 03-02-2013, 02:59 AM
K9ENDY's Avatar
K9ENDY K9ENDY is offline
Vehicle: 2013 Dodge Ram CC
Rep:175
Default 2013 Interior LED Install HELP
So all the instructions that I've read so far say to pop off the lens cover and pull the bulb out. The 2013's have the chrome plate in there and the plastic housing that has the bulb behind it. Do I need to remove the entire overhead assembly to get behind the chrome plate and housing to get to the bulb? I don't wanna pop stuff off and risk breaking it if I don't have to. Thank you!!
Old 03-03-2013, 05:39 AM
K9ENDY's Avatar
Rep:175
And I tried the map light tonight, same issue. The bulb is encased within another lense which also has a chrome plastic piece completely filling up the area behind the lense cover. It isn't obvious how to get to the bulb. Any insight out there?
Old 03-03-2013, 07:41 AM
av41medic's Avatar
av41medic av41medic is offline
Vehicle: 2013 Ram Sport 4X4 CC
Color: Deep Cherry Red
Rep:16
av41medic is on a distinguished road
I have been searching on the web non stop all morning to no success. All I've come accross is people in 2012's having flickering problems as well. I will continue to search.
Old 03-03-2013, 09:21 AM
Rep:1882
08 - Electrical/8L - Lamps and Lighting/Lamps/Lighting - Interior/LAMP, Reading/Removal
REMOVAL
NOTE:On vehicles equipped with an optional overhead console the standard front dome lamp is replaced by two combination dome and reading lamps that are integral to the console housing. Each of these lamps is controlled by the door ajar switches on the courtesy lamp circuit, but also are independently controlled by a switch that is activated by depressing the lamp lens. The bulb types and service procedures are identical for both of these lamps.
NOTE:The overhead console reading lamp switches and bulb holders are serviced as a unit with the overhead console wire harness.
  1. Disconnect and isolate the battery negative cable.
  2. Using a small thin-bladed screwdriver, gently pry near the front of the lamp lens between each side and the overhead console housing (1) to unsnap the pivot tabs (3) on the lens from the pivots in the lamp housing.
  3. With the lens disengaged from both pivots, pull the lens forward far enough to disengage the switch tab (2) on the rear edge of the lens from the slot in the rear of the overhead console lamp housing.
  4. Remove the lens from the housing.
  5. Firmly grasp the bulb (1) and pull it straight out of the socket.
Old 03-03-2013, 10:26 AM
K9ENDY's Avatar
Rep:175
REMOVAL
I think that ended in 2012. The bulb is now contained in yet another housing past the initial lenses. That's the one I'm having problems with. I can see the bulb but there's no way to get to it thru the little opening that's available. I have now seen enough (just tried again) to know I ordered the wrong bulb for this new-fangled system or at least the ones I ordered seem a little bigger. The rear light is very similar and will probably need the exact same dis-assembly.
Here is a pic. The right side has the lens off and this is what's past it. Thanks for taking the time to reply!!
Old 03-04-2013, 08:17 AM
Rep:1882
Interesting. This is straight from the '13 manual. I can't say I'm surprised though; this isn't the first time a system was updated and the old info left in the manual.
Old 03-04-2013, 09:30 AM
K9ENDY's Avatar
Rep:175
Wow, that kind of surprises me. So does that mean that if I take it to the dealership they probably won't know either? If so, I guess I could just bump this thread in a few months and see if anyone has figured it out yet. I'm in no hurry to break something. Lol.
Old 03-15-2013, 11:09 PM
K9ENDY's Avatar
Rep:175
Bump. Still looking if anyone has any info.
Old 03-30-2013, 11:01 PM
K9ENDY's Avatar
Rep:175
Another bump. Hopefully someone will eventually see this that has some info. Everytime I see those blue lights in my girlfriend's Challenger I get jealous.
Old 10-01-2013, 01:35 AM
dustin72's Avatar
dustin72 dustin72 is offline
Vehicle: 2013 Dodge Ram1500 4x4
Rep:48
dustin72 is on a distinguished road
Anyone figure this out yet? Ran into the same issue on my '13.
Black SRT10 22's with 305/45/22 Nitto NT420S Tires, 6000k Low and Fog HID's, Debadged, Tint, Custom Mopar Badges, S&B Intake, Magnaflow Muffler, Superchips Tuner
