Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Suspension
Old 02-24-2013, 08:37 PM
Zane-s Zane-s is offline
Vehicle: 2009 Dodge Ram
Trim Level: 1500 TRX
Zane-s is on a distinguished road
Default Suspension swap on a 4th generation Ram?
Okay, so my question plain and simple is can you do a suspension swap up on a 4th generation Ram? I have a 2009 Dodge Ram 1500 and I am looking for a relatively easy way to get a lift and I would also like to increase my payload. I understand that a 1500 is not built to handle the same payload capacities as a 2500 but I would only be utilizing the upgraded payload for a very short time each use, plus I am working on upgrades which would give me more power. Things like a cold air intake, electronically controlled straight pipes, new camshaft, throttle body spacer and possibly performance heads. I am also looking at price as a factor, if I can do a suspension swap, I can just run down to a wrecking yard and pick up a suspension kit from a 2500. So is it possible?
Old 02-25-2013, 12:13 AM
Ramzaq Ramzaq is offline
Vehicle: 2009 Ram CC 4X4
Trim Level: SLT, Big Horn
Color: Black Pearl coat
Rep:233
Ramzaq has a spectacular aura aboutRamzaq has a spectacular aura aboutRamzaq has a spectacular aura about
No!
4th gen 1500's all have coil spring suspension, all 2500's have leaf spring suspension and the are not compatible.
Old 03-01-2013, 10:51 AM
JMS4218 JMS4218 is offline
Vehicle: 2014 Ram Sport crew cab
Color: Blue streak pearl
Rep:83
JMS4218 will become famous soon enough
If you going to go that far just buy a 2500
Old 03-01-2013, 02:11 PM
seanbeckaroo seanbeckaroo is offline
Vehicle: 2009 Ram 1500 Crew Cab
Trim Level: SLT-Big Horn
Color: Blue, Sexy Blue
Rep:66
seanbeckaroo will become famous soon enough
Check these out, 50% capacity spring increase from stock, might be what you are looking for. and for about $200, you can't beat it!
http://www.sdtrucksprings.com/index....125&x=116&y=18
Old 03-05-2013, 10:01 AM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Add TLC
Just add TotalLoadControl and your truck will be level even at the max weight limit.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
2009 dodge ram, suspension, suspension lift, upgrades
