Old 03-02-2013, 01:26 AM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I love it, great right up I will be using this for reference soon I think, this should be stickied IMO
Thanks
Jeremiah
Discount Auto Performance
Old 03-02-2013, 04:04 AM
Scotty85's Avatar
Scotty85 Scotty85 is offline
Vehicle: 2012 Dodge Ram
Color: True Blue Pearlcoat
Rep:79
Scotty85 will become famous soon enough
Thanks! This mod is definitely not for everyone. I feel anyone with at least some soldering skills should at least try it on something like the headlight switch. If you can do that, then you should be able to to the rest of it as well.
2012 RAM Sport CC Hemi - Photos here:http://www.ramforumz.com/showthread.php?t=132968
Audio Mods - http://www.ramforumz.com/showthread.php?p=1005034
Perf. Mods - http://www.ramforumz.com/showthread.php?p=1005080
Body Mods - http://www.ramforumz.com/showthread.php?p=1005083
Old 03-02-2013, 11:03 AM
CdnoilRAM CdnoilRAM is online now
I push the skinny pedal
Rep:3277
Originally Posted by Manutea View Post
Is it the same for 3rd Gen ?
Thanks for all the tips
The 3rd gens are different, they have vertical switches and the smd leds are mounted inside the switch housing, a complete bitch to get to with a soldering iron. I pulled mine apart when I did my amber lighting swap. The center controls use warm white leds for everything and have a green-tinted gel on the underside of the display panel. The gel can be removed carefully using acetone, but too much and you can remove the white diffusion material and distort any lettering/numbers. I believe I did a write up on this a while ago, but I'd have to search for it. I wasnt that impressed with the switches and replaced then with a stock unit.
Kurtis
Old 03-02-2013, 11:45 AM
Scotty85's Avatar
Rep:79
So when can I send you mine with some cash stuffed inside? I like green btw...
LOL. Well, the stock ones are "green"... but not GREEN green. Green would look very cool if you had everything else matching or color-coded to that. That would look killer!
Scott
Old 03-05-2013, 10:03 PM
Scotty85's Avatar
Rep:79
HomeLink Buttons
Needed:
T20 Torx
Trim tool
Long, thin screwdriver
(3) 3.2mm x 2.8mm LEDs http://www.mouser.com/ProductDetail/...KevPv2k5b2IKR3
First things first. This is a complete and total bitch to remove. The wires up here are so short that it's almost (but not quite) impossible to unplug everything. I had to use a long, thin flat-bladed screwdriver in order to push some of the plug clips back to get them loose, and they are tight as hell. That's the whole reason I don't have any more pics of getting it down. Sorry. Anyway, here goes!
Here's where you get the plugs loose.
/insert cursing and swearing loudly/
Then you take the module out of the panel.
I have everything else done inside the truck. I have the steering wheel controls done as well.
To be continued....
Scott
Old 03-06-2013, 01:36 PM
Rayne's Avatar
Rayne Rayne is offline
Rep:73
I get nervous even reading the steps and looking at your pictures. I definitely wont be attempting this one but I can certainly appreciate what you have done!
Old 03-06-2013, 01:39 PM
Scotty85's Avatar
Rep:79
There's really nothing to it. I don't get why everyone is so scared of it. Not for everyone, I guess.
Old 03-06-2013, 01:44 PM
KA1OTE's Avatar
KA1OTE KA1OTE is offline
Ram Ham
Color: Mineral Gray Metallic
Rep:1475
I *really* want to do this.. all of it! Thanks to your write ups and links to the LEDs to buy, I know I can get everything I need to do these projects.. But my problem is I have no earthly clue how to solder! Seems I need to bribe my husband with beer, brats and
Old 03-06-2013, 03:08 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
Bad azz man. Good job... Sending some reps your way.
Old 03-07-2013, 12:31 AM
Beaster's Avatar
Beaster Beaster is offline
Vehicle: 2012 Dodge Ram 1500
Rep:17
Beaster is on a distinguished road
Kick ass work Scotty they look great! Props and rep to you. I wish I trusted myself enough with a soldering gun to attempt this. Is this the same process needed for the bulb in the upper console that shines down on the shifter and cup holders in the the center console?
Brent's '12 Sport: Spyder CCFL Headlights & Tails, Plasmaglow Lightbar, Grill Inserts, Hood Scoop LED's, Flowmaster Super 10
