Old 02-25-2013, 06:43 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Originally Posted by Hemi N Haw View Post
I'm sure you already know 3 things make an engine run. Air-Fuel & Spark. If she was running rough & throwing misfire codes w/ your tune in it but then your tune was removed & the codes were cleared next you tried to fire it up then the engine cranked w/ no bang or pop. The codes are gone but the s.e.l. stays on? I'm just curious if when you attempted to fire it up if you heard the fuel pump running or not?
that is a very good point, I am curious to this as well.
Very interested to see what they come up with please keep us posted
And so sorry to hear about your misfortune.
Thanks
Jeremiah
Discount Auto Performance
Old 02-25-2013, 10:20 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Wink
Ok so I was contemplating your no go issue my friend. It's not the y pipe or at least I don't believe. Any ways this tune jammy peaked my interest as I want one down the road a piece & for the reason of mods & fuel eco adjustment which brings me to my point. You mentioned you had a tune uploaded for fuel eco. So it comes to me that fire burns cool w/ more fuel & hotter w/ just enough fuel & lots of oxygen. It may very well be that the tune is doing one of two things or both. Your e.c.m. is sending just a c.h. of fuel enough to make a spark & then normal/ excessive amounts of air into the combustion chamber. This may cause standard plugs to degrade due to excessive heat hence the misfires. Or it's leaning out your injectors so much that the very fuel the engine runs on in addition the injectors are lubricated by are getting burned out on. Or both of these things are happening & bam your whole ignition process is ka-bleewy!!! Just a guess & truthfully I hope not cause like I said I wanna run a tuner in my ram down the road. So best of luck & hope your back up & running w/ handy post on what caused all our speculation in the first place.
