Old 02-24-2013, 03:46 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
RamTech, Sorry but have seen first hand exhaust welded on a early 2000 gm truck.
When done truck would not start. The problem, ECU fried. It can and does happen.
Maybe on the newer stuff the car companies fixed this.
When I worked at NAPA, if you replaced your ECU for whatever reason, it stated to make a ground from your body to frame to prevent static electricity from zapping ECU. So there must be something to this.
Forgot, my local bodyshop "always" unhooks battery before working/welding on cars/trucks.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it's harder if your stupid."
How would you know?
Old 02-24-2013, 09:04 PM
Rep:1877
I'm not saying it can't happen, I'm saying that your statement about not welding on computer controlled vehicles is wrong.
Old 02-24-2013, 09:10 PM
Originally Posted by RamTech View Post
After looking at the potential causes for the P0884, I can't help but wonder if some tranny wiring was damaged during the Y-pipe install. From what I see, the tuner wouldn't be at fault here unless something really went bat-shit crazy and is causing false codes to pop up. What this code is esentially saying is that power to the TCM portion of the PCM went off and came back on while the truck was rolling down the road.
RamTech, this is why you are so valuable to the Z
Old 02-24-2013, 09:57 PM
oldhp's Avatar
Color: WHITE
Rep:902
Well I disagree. Too many ECU's, MSD boxes that don't work after welding on vehicle.
To me why even take the chance. Some guys do, some don't.
I will agree to disagree.
How would you know?
Old 02-25-2013, 12:26 PM
Rep:1877
That's fine, but please don't post incorrect information on the forum.
Old 02-25-2013, 02:06 PM
oldhp's Avatar
Color: WHITE
Rep:902
Clifford17, Have you found out anything yet???
How would you know?
Old 02-25-2013, 04:18 PM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
dealer said the engine light is off and still no start.... they are thinking it is bad gas, but I disagree cause it acted up before I filled the tank....
Old 02-25-2013, 04:25 PM
bad gas?
keep us posted on this....
Old 02-25-2013, 05:04 PM
dodgeboy360's Avatar
Vehicle: 2015 Dodge Ram
Color: Granite
Rep:505
It's definitely not bad gas.... To me it sounds like he was driving and it was running rough which indicates its not running on all cylinders.. And then the engine light comes on and confirms that's indeed it has a misfire.. To me it sounds like a coil issue / ignition so as he kept driving it. It most likely went into a limp mode and now won't start as a safety issue to prevent further damage to that cylinder .. Such as being washed out from the fuel exc....
Trailer tow package, husky liners, timbrens, more to come
Old 02-25-2013, 05:15 PM
Hemi N Haw's Avatar
Hemi N Haw Hemi N Haw is offline
Vehicle: 2012 Ram 1500 Laramie Crew cab
Color: Bright White-W7
Rep:139
Hemi N Haw will become famous soon enoughHemi N Haw will become famous soon enough
Smile
I'm sure you already know 3 things make an engine run. Air-Fuel & Spark. If she was running rough & throwing misfire codes w/ your tune in it but then your tune was removed & the codes were cleared next you tried to fire it up then the engine cranked w/ no bang or pop. The codes are gone but the s.e.l. stays on? I'm just curious if when you attempted to fire it up if you heard the fuel pump running or not?
