Old 02-19-2013, 05:32 PM
cawish33 cawish33 is offline
Vehicle: 2011 dodge ram
Trim Level: sport q/c
Color: hunter green pearl
cawish33 is on a distinguished road
Default 2011 ZF axles vs 9.25 chrysler 4.56:1 ratio
this is to clear this out between the two axle in our dodge ram 1500 , if you think changing ratio to your truck , carefully check the rear end and the front diff
ok as the title says all the 2011 + rear end diff as the new zf axle internal, well it is a 9.25 chrysler with a zf interrior. i compare the two carrier bearing etc.. it's all the same except for the bolt in ring gear the zf is a lot bigger than the older 9.25, the axle spline are the same, so the ZF is a lot heavy duty interior for the ring gear bigger bolt,
so if you wanna go 4.56 you have 2 choice, the first is to swap a 9.25 chrysler carrier and you can put every ratio you want as before , and 2, drill out the new ring gear and tap new thread to bolt straight to new zf interior.
as for the front all the 2011 and older are the lucky one
the diif in the front is a 8 inch chrysler , same as the older 2002 to 2011 ram 1500 except for the 2002 - 2005 as the manual shift for 4x4 but they all the same diff, so for the 4.56 on the front end is just a swap gear. on the 2012 + it is the same as 2011 except the ring gear is solder to the carrier and it is a new internal zf too so the only thing you can do is to swap the entire front diff for a 2006-2011 ifs 8 inch chrysler
i just ordered my front and rear gear , i will post picture of the install and the 2 carrier difference
Old 02-19-2013, 08:15 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:643
you are able to this your self?
Old 02-19-2013, 09:09 PM
not alone , i have a friend who have a 4x4 differential and tuning shop here and today we open my diff to see what is can be done with ZF and to our suprise , the old 9.25 carrier chrysler on the previous ram fit beautiful , even the bearing and spline on the axle, so we ordered the motive 4.56 gear and we gonna install this thursday !! i will post and take a lot of picture of modification and install. to make the install easier
Old 02-20-2013, 10:04 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Welcome to the 4.56 club!! You're gonna like the change. I've got 20k on my Yukon 4.56s and running STRONG
[CENTER][SIGPIC][/SIGPIC]
Old 02-20-2013, 02:20 PM
ohhh my !! can't wait to see the beast wake up with the 37 bf !!
it is not that bad with the 3.92 ratio but with the 4.56 i know it's gonna be better !
Old 02-20-2013, 02:34 PM
candy08's Avatar
Rep:213
It'll wake it up. I went from 3.55 and 37" Swampers to 4.56s and 37" Swampers....brings all your lowend AND some back lol. With your light BFGs you'll definately be quick. Diablo 87 tune on 93 octane does this with 10" of lift and 37s haha
Old 02-20-2013, 02:38 PM
that sick result !! and this is with 37 tire !!!
Old 02-20-2013, 06:15 PM
Jayincali's Avatar
Jayincali Jayincali is offline
Vehicle: 2014 Dodge Ram 8 Speed 3.92
Color: Deep Cherry Red Crystal Peral
Rep:95
Jayincali will become famous soon enough
So having a 2011, I can pull all the guts out of the ZF rearend and install a Trutrac and gears with no issue?
Old 02-20-2013, 09:46 PM
yes all the 9.25 chrysler diff interior can be swap carrier, bearing etc..
tomorow i will post picture from the 2 diff , the zf and the 9.25
Old 02-20-2013, 10:12 PM
candy08's Avatar
Rep:213
You haven't actually tore the rearend apart yet have you?
