Old 02-14-2013, 08:02 PM
ironchef2011's Avatar
ironchef2011 ironchef2011 is offline
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
ironchef2011 will become famous soon enoughironchef2011 will become famous soon enough
Default Ground Force Rear Drop- Instructions?
I'm having a brain fart night. I'm looking for a how to/detailed instructions for installing the Ground Force rear leveling kit on my 2012 R/T. I know I've seen it here on the forum somewhere but I've searched for the last hour and came up empty!
2012 R/T 392
Old 02-15-2013, 12:08 AM
dodgert's Avatar
dodgert dodgert is offline
Vehicle: 2011 dodge ram rt
Trim Level: rt
Color: brilliant black pearl
Rep:1061
i can walk you through it and to bad you bought one ill be selling mine for super cheap
Old 02-15-2013, 04:46 AM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Walk away! The shock and spring replacement is self explanatory I imagine. It's the drilling a new hole thing that has me a bit concerned.
2012 R/T 392
Old 02-15-2013, 01:34 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
so your dropping the rear 2'' correct if so then you dont need to drill holes if its telling you that then you got the wrong instructions to drop it 2'' its remove the stock stuff replace springs and shocks. Jack up the rear support the frame with jack stands use your jack on the pumpkin un do the shocks and rear sway bar slowly lower the rear, watch the break lines youll be ok but dont want to drop it to fast. The springs should almost fall out put new one in put in new shocks and gtg
Old 02-15-2013, 01:40 PM
Vehicle: 2012 R/T
Trim Level: R/T
Rep:120
Perfect! It's not telling me to do that but I thought I read it somewhere. That must be for the people who lower the rear and the front, 3-4" rear drop total.
And yes, mine is just the 2" leveler.
2012 R/T 392
Old 02-15-2013, 08:03 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
if you drop the rear 4 inches they actually give you a relocation kit so no more drilling
Old 02-16-2013, 05:15 PM
13RT's Avatar
13RT 13RT is offline
Vehicle: 13 RT
Trim Level: RT
13RT is on a distinguished road
Will yours work on a '13 ?
Old 02-16-2013, 05:43 PM
dodgert's Avatar
Trim Level: rt
Rep:1061
humm i believe its the same set up as the rest so id say yes
Old 02-18-2013, 02:39 PM
13RT's Avatar
Vehicle: 13 RT
Trim Level: RT
Shoot me a price PM if needed
Old 02-18-2013, 05:28 PM
snrusnak's Avatar
snrusnak snrusnak is offline
Rep:1385
It's super easy to swap the rear springs. Basically lift truck, pull out springs, insert new springs. Might take slight prying with a long screwdriver but it's extremely self explanatory and easy.
Sean
