Old 02-08-2013, 02:58 PM
lemon126's Avatar
lemon126 lemon126 is offline
Vehicle: 2005 Ram 1500 Quad Cab 4x4
Color: Burgandy
lemon126 is on a distinguished road
Default Engine ticking making me nuts
There's a tick in my engine thats making me nuts. Still warrantied, so i took it to the dealer and they replaced the belt thinking that was it. Still have the noise and a friend told me he thinks maybe it's the rockers making the noise.
Any suggestions on what else it could be? I have 85K on the engine.
Old 02-08-2013, 03:23 PM
Asur Asur is offline
Vehicle: .
Rep:4371
I had a ticking like that, it used to come and go, I switched over to full synthetic and for me it stopped doing it. Don't know if that can help you.
Old 02-08-2013, 03:29 PM
Rep:1877
Your engine doesn't have rockers. It uses a system of lash adjusters and cam followers and a lash adjuster could be the cause.
Old 02-09-2013, 07:56 AM
lemon126's Avatar
Color: Burgandy
Thanks for the input. I"ll start with the synth oil first and hope that helps.
Old 02-09-2013, 09:56 AM
Vehicle: .
Rep:4371
Talk to Jhinkle about amsoil, they can get you good pricing, There one of the sponsors of this site Discount Auto Performance
Old 02-09-2013, 11:51 AM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
alot of people have this tic runnin low grade gasoline maybe try runnin a higher octane
Old 02-09-2013, 12:08 PM
Vehicle: .
Rep:4371
On the hemi its common to have the tick when not running 89 and at different sea level, but on the 4.7 its not the same tic,
Old 02-09-2013, 10:25 PM
lemon126's Avatar
Color: Burgandy
I threw some Sea Foam in the oil fill and gas tank today with the hopes that maybe it would clean it a bit and quit the noise. Didn't do much. And I also saw a video on you tube that says U need to change the oil a hundred miles or so after Sea Foam is used. Woops........guess I'll be doing premature oil change tommorow. Well no better time to throw some synth in and see if that helps!
Old 02-10-2013, 10:39 AM
Vehicle: .
Rep:4371
Keep us posted on how it turns out.
Old 02-10-2013, 03:35 PM
lemon126's Avatar
Color: Burgandy
So I did an oil change with Mobil 1 synthetic and Fram Ultra filter. It may be wishful thinking, but I believe it sounds a little quieter as far as the tic is concerned, but it"s still there. I'm gonna burn the rest of the gas in the tank then go to 89 and see if theres a change.
