Old 02-01-2013, 09:25 PM
crazychevy88 crazychevy88 is offline
Vehicle: 2004 dodge ram
Color: silver
crazychevy88 is on a distinguished road
Default Alotta noise for a lil air
So my AC blows cold, and my heat is hot (atleast as hot as it gets with a 160 thermostat) but it seems to be lacking in the movement. If I crank the blower all the way up I can hear it pusing harder (sounds like a wind tunnel) but its not getting to the vents. Any quick fixes that don't involve tearing my entire dash out? Thanks in advance guys!
Old 04-02-2013, 10:45 PM
slaghammer slaghammer is offline
Vehicle: 2006 Ram 1500
slaghammer is on a distinguished road
I posted the same problem a while back for my '06.
It appeared that the problem was with the Blend Door from what others had experienced. The Tech at the dealership told me that it was actually the Blend Body and it would take about 8 hours of labor which involved removing the dash to the tune of about $900. If you hear of another way to correct this, let me know. Good luck
Old 05-06-2013, 10:38 PM
DodgieDan DodgieDan is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
DodgieDan is on a distinguished road
There is a you tube video on fixing the blend doors without taking the 8 hours that the service center wants. I downloaded the videos to disc and took them to my local repair shop and they did the work in 3 hours. I will post later with the link.
Old 08-18-2013, 01:31 AM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
I searched YouTube but couldn't find the answer to this particular problem. I have the SAM thing going on but there doesn't appear to be a broken blend door blocking the fan. Please tell me I don't have to pull the whole dash.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 08-27-2013, 08:42 PM
AzHunter's Avatar
AzHunter AzHunter is offline
Vehicle: 2006 Dodge Ram Quad Cab 4x4
Trim Level: LARAMIE QQ 4x4 3.92
Rep:52
AzHunter will become famous soon enough
Anyone have an update on this? I have a 06 that just started doing the same thing today. Sounds like it is blowing HARD but only a little bit of air is getting out the vents.
If i can kill it with an arrow, I'll eat it.
Old 08-27-2013, 10:41 PM
Color: tan
Rep:65
I found a video on you tube. The recirculate door breaks and blocks the fan. Have to go in behind the glove box. I just took the door out. I will replace it later.
Old 08-28-2013, 12:42 AM
AzHunter's Avatar
Rep:52
This guy has videos on how to diagnose what door or motor is the problem and how to fix it. Very cool. He sells the replacement doors but that have metal parts where the OEM plastic breaks.
My ReCirculating door broke at the motor connection. That caused my problem which was the same as CrazyChevy explained. After watching the videos, I broke the grill out and pulled the door out. It was sitting on the air intake blocking nearly all the airflow to the fan. Will replace later with a door from Heater Treater.
Old 09-01-2013, 05:24 PM
mb power wagon's Avatar
mb power wagon mb power wagon is offline
Vehicle: 2007 dodge power wagon
Trim Level: power wagon
Rep:68
mb power wagon will become famous soon enough
try pulling out the blower motor and see if you find anything broken. easy to get to and easy to check and it won't cost you anything to do it yourself.
Old 09-01-2013, 06:01 PM
Rep:2625
go to youtube
look for HEATER TREATER DODGE
Old 10-29-2013, 09:48 PM
Topdragster Topdragster is offline
Vehicle: 2006 Dodge Megacab
Color: gray
Topdragster is on a distinguished road
same problem here. took me five minutes to pull the blower motor down (3 Screws) either use a socket or a torxs. tip door up and pulled it out through blower motor hole. will look for a new door.whos selling doors lol
