United Radio
Old 01-29-2013, 11:03 PM
Boubou's Avatar
Boubou Boubou is offline
Vehicle: 2010 Dodge Ram QC 4X4 Hemi
Trim Level: 4X4 SLT Hemi
Color: Light greystone
Rep:54
Boubou will become famous soon enough
Default 20" rims painted aluminum wheel
I have looked everywhere and cannot find the info I need.
I am pretty sure one of you knows the answer.
I am towing a small fifth wheel and changed the Goodyear tires to Michelins LTX/AT2 275/65R20 max load: 3750 lbs. @ 80 psi
I run them at about 50 to 55 psi when loaded.
Question is: I don't think they put in a steel valve in there (but I think I may have found the answer to that, if I run them below 65 psi, that is ok)
http://www.tirerack.com/tires/tirete...jsp?techid=208
My main question is: someone told me to make sure that the rims can take the extra PSI. I looked at the rims and cannot find any maximum numbers on them.
Anyone knows this?
and one more question, is how do I figure how much air I need to add with the extra weight? is there a formula for that?
Thank you!
Last edited by Boubou; 01-29-2013 at 11:13 PM. Reason: need to delete this, put it in the wrong thread
michelins, psi, rims, towing
