Old 01-25-2013, 10:37 PM
JPartridgekk's Avatar
JPartridgekk JPartridgekk is offline
Vehicle: 2012 Ram Big Horn
Color: Mineral Gray Metallic Clearcoat
JPartridgekk is on a distinguished road
Post Will 35x13.50xr20's Fit my 12' Ram 4x4
I found a guy on CL that wants to trade his MOTO Metal 20x10 wheels with 35x13.50xr20 Pro Comp AT's for Stock 20's, He has them on a 10' 2wd with a 2" leveling kit and says they dont rub? I find that hard to believe but thought one of you guys may know ,
2012 RAM 5.7 HEMI, Diablo Intune DCX, K&N cold air intake, 18" magnaflow exhaust, Carbon Fiber Shorty antenna, BAK INDUSTRIES Rollbak G2 bedcover, Spray in bedliner, XD Rockstars W/ 305/50R20 Nitto Terra Grapplers, Bilstein 5100's Set at 2.8, TGC 3/4" Rear Coil Spacer.
Old 01-25-2013, 10:58 PM
bigreid's Avatar
bigreid bigreid is offline
Vehicle: 2011 Ram
Rep:23
bigreid is on a distinguished road
he may be referring to the readylift sst leveling kit. It raises the front and the rear and the website says that it'll fit 35s
Project Diamondback
Old 01-25-2013, 11:24 PM
Thanks, i'll look into those. I really cant find anything that says for sure one way or the other
Old 01-26-2013, 09:17 AM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
i find it hard to beleive he does not rub either im runnin 12.5 wide on stock twenty leveled and had to add 1/4" spacer
Old 01-26-2013, 09:58 AM
Thats what I thought I went ahead and ordered the Bilstein 5100 adjustable shocks for the front lastnight after tons of research hope i'm making the right choice! lol do you have any pics of your rig with the factorys and spacers? and what kind and size tires are you running?
Old 01-26-2013, 10:03 AM
starquestbd22's Avatar
Trim Level: Sport quad cab
Rep:367
With an aftermarket rim I don't find it hard to believe that they don't rub on the inside. That's just a matter of enough negative offset. But at 13.5" wide I do wonder about them rubbing on the fender. Even if they don't rub, if they are that wide and have that much offset I bet they stick out a couple of inches.
Old 01-26-2013, 10:40 AM
Yes from the pics he sent they definitly stick out a couple of inches. but he was unsure of the wheels actaul offset.
Old 01-26-2013, 10:44 AM
joelwalls's Avatar
Trim Level: sport
im runnin35x12.5 durun mt bilstiens at 2.8 1.5 rear spacer
leveling kits, rubbing, tires, wheels
