Old 02-24-2014, 01:30 AM
Campbell402's Avatar
Campbell402 Campbell402 is offline
Vehicle: 2014 Ram 1500
Rep:73
Campbell402 will become famous soon enough
There is also a sticker on the rear diff if you look under it
Another way is to put it on jack stands, but calling the dealer would be easier. Just I case anyone wants to know how to do it here's how...
This is probably the easiest way to measure your rearend ratio, as it doesn't require removing the differential cover. Jack up the rear end of the truck (so that both rear tires are off the ground) and make a mark (or pick a spot) on both the driveshaft and a rear tire. With the transmission in neutral, spin the tire by hand through one rotation, and count the number of times the driveshaft turns. The number of driveshaft rotations is your rearend ratio. (For example, if the driveshaft turns about three and a half times, the ratio is probably 3.55. If its almost three and a quarter, the ratio is probably 3.21. Almost four times, 3.91s, etc.
The procedure above applies if you have a Sure Grip (limited slip) differential or a locker. If you have an open differential, the procedure is the same, but you will need to spin the tire through two rotations instead of just one.
Old 02-24-2014, 08:38 PM
draken's Avatar
draken draken is offline
Vehicle: 2010 Dodge Ram 1500 CC Bighorn
Trim Level: Bighorn. SLT
Rep:19
draken is on a distinguished road
Thank you!
Zone 6" Suspension with 5" rear, Bilstein 5100s, Toyo M/T 315/70/18, 18x10 MotoMetal 967s, Bushwacker Pocket Flares, Flowmaster 10 series, Diablo Trinity With Hemifever Tune, Drop in K&N Filter, Retrofitted headlights, 5k morimoto HID, 6k Fogs, Metal Tonneau Cover, Plastidipped Bumpers and Grille
Old 03-01-2014, 10:03 PM
cSMITH3100's Avatar
cSMITH3100 cSMITH3100 is offline
Vehicle: 2013 Dodge Ram shorty
Rep:73
cSMITH3100 will become famous soon enough
anyone run into a rattling in the rear of their truck after the lift? when I drive over some rough patches i will here a slight rattling like something is loose in the back some where, Iv checked multiple times underneath and everything is tight. The only thing I can think of that could be causing the rattling is the rear spacers may be wiggling just enough to cause the rattle? where it is a shorty, could the weight difference maybe be causing it to not push down on the spacers and hold them in place tightly?
Old 03-02-2014, 08:53 PM
Ram725's Avatar
Ram725 Ram725 is offline
Vehicle: 2012 Ram 2500 4x4
Rep:347
I had it as well. Could never find it. Tried replacing the rear coils. Didn't work. Then I took to RCX head quarters and they couldn't find it. The new owner claims he fixed it because a crossmember bolt was loose. But think he was making that up.
SOLD: 2012 Ram 2500 CTD 4x4
Old 03-02-2014, 10:38 PM
cSMITH3100's Avatar
Rep:73
so it is an uncurable rattle then? lol
Old 03-04-2014, 03:54 PM
Pimppapa1977's Avatar
Pimppapa1977 Pimppapa1977 is offline
Vehicle: 2007 RAM
Color: Grey
Rep:16
Pimppapa1977 is on a distinguished road
OK dropped my 07 off today for my RCX lift install. I have looked all over for this answer. What setting should I have them put the BIlsteins at to sit level 1.4 or 2.1? I searched, and searched with no clear answer. Any help would be greatly appreciated!!!
Old 03-04-2014, 04:09 PM
brandonjansen's Avatar
Lifted Cummins Fanatic
Trim Level: Laramie Limited
Rep:2026
If it's a 6" lift you'll probably want them at 1.4". For a 4" lift you'll want them at 0.7".
Old 03-05-2014, 01:04 AM
Right there
Old 03-12-2014, 03:47 PM
bandhunter1754 bandhunter1754 is offline
Vehicle: 2012 Ram 1500
bandhunter1754 is on a distinguished road
Fast - I cant seem to find any of the bilstein or RCX products on the website, are they special order? Also I see you are from Toronto, does the company ship from Canada?
Old 03-12-2014, 03:55 PM
Rep:2026
Bully's is still currently working on loading products into their new website so you probably won't find them there yet. But if you email Andrew at fastnugly@bullysperformance.com letting him know what you want he'll send you a quote and then if you want to purchase it, a custom cart link to their website with the products you want.
