Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram – 2009+ Dodge Ram Trucks > Towing
Old 03-05-2013, 06:35 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
airlift + magnaflow muffler from Discount Auto Performance = huge savings, whenever you are ready and know what you want let me know I would be more than happy to pull a quote for you
Thanks
Jeremiah
Old 03-23-2013, 11:42 PM
TLC John's Avatar
TLC John TLC John is offline
Vehicle: 2006 Dodge RAM
Rep:17
TLC John is on a distinguished road
Default Airlift v. TLC
Almost every week it seems we are getting new customers ordering TLC™ who have the "inside the coil spring bags".
TLC is rated over 5,000 pounds of lift v. 1,000 pounds of lift.
TLC has heavy duty rubber air springs v. plastic sleeves.
TLC levels heavy loads at 20-30 psi v. 50-100 psi.
TLC current sale price is about $400 v. $100.
Of course, you can't just look at price.
Total Load Control™
Revolutionary Air Suspension for RAM 1500 2500 3500
Level Every Load with TotalLoadControl.com
Old 03-29-2013, 12:35 PM
NewRamGuy81's Avatar
NewRamGuy81 NewRamGuy81 is offline
Vehicle: 2012 Ram 1500 Express
Rep:12
NewRamGuy81 is on a distinguished road
Dont go with the mufflex it is junk and does not mount up well. I ordered one and of course does not quite line up right. Go to a muffler shop and have them cut out the muffler and install a magno, flowmaster etc.... I cut out the mufflex mounts and just used the muffler save yourself the hassle and it will be cheaper. Dont go with the airlift 1000's this setup is a joke and you will not be happy with it. You have plenty of room to install a tru air bag setup I have Airlift Dominators on mine mounted up nicely here is a photo.
Old 04-01-2013, 12:01 AM
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
Do you have a larger size picture? kind of hard to see the smaller one above.
Thanks
Jeremiah
Old 05-07-2013, 03:14 AM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I have an airlift 1000. Put it in the second day I owned the truck.
Works great!
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 05-07-2013, 11:50 AM
jgos929 jgos929 is offline
Vehicle: 2012 Dodge Ram
Trim Level: SLT Lone Star
Color: Sagebrush
Rep:-5
jgos929 has a little shameless behaviour in the past
Originally Posted by Outdoorsman2012 View Post
Thanks for the info guys! I did go with the Airlift only bc i was able to get if for $25. I want a nice exhaust but don't see the point in replacing the entire system. Just started looking at Mufflex and thinking thats they way I'm going to go. Looking at the aggressive or Moderate. Just don't want the drone to be to bad because I plan on keeping the MDS on.
Mufflex is junk and WAY over priced. Save yourself $100+ and time on your back and just buy the muffler and have it welded in. You'll be a lot happier.
I like the TLC system but isn't some of the above misleading? Such as the 5K vs 1K pounds of lift. You simply cant put 5K worth of weight in the bed of your truck, technically depending on the model you shouldn't even have 2K in the bed of the truck. 5K of lift is nice but you're still overloading the axles and tires so it's kind of overkill. And the 20-30psi vs 50-100psi. The airlift system has a max of 35psi and most folks that have them don't see a need to inflate them that high to level the load.
I have he A1000 bags and I went with them simply because of all the good reviews I read and the price is great. I like the TLC system a lot because its a well put together system but at the time it was out of the price range.
No mater what you chose bags are definitely needed with these coil spring trucks.
Old 05-07-2013, 03:42 PM
TLC John's Avatar
Rep:17
The first rule, of course, is never exceed the GVWR or GCWR.
I mentioned TLC 5K v. AL1000 1K capacity to describe the power of the TLC system versus others.
Even though TLC has way more lift capacity than needed, this allows TLC to operate at lower air pressure (10-30 psi) and deliver maximum control and comfort loaded and unloaded.
Many TLC customers have switched from AL1000 because of the power and performance of TLC. We have not had a single customer trade their TLC system for AL1000.
Total Load Control™
Old 05-11-2013, 10:07 AM
61Dodge 61Dodge is offline
Vehicle: 2013 Ram 1500 RCLB 4x4 3.92 Ls
Trim Level: Tradesman
Color: Mineral Gray Metalic
Rep:23
61Dodge is on a distinguished road
I went with the air lift for under a $100.00 it is hard to beat. I am very happy with it. Later on if I decide to with the total load control, I figure I will have gotten more than my money out of my air lifts.
Wife's ride 2004 Black Durango 4.7
Oldest Dodge 61 Baby Blue D100 slant 6 with 3 on the tree
airlift, muffler, suspension, towing
