Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
Old 01-21-2013, 03:37 PM
djdado7's Avatar
djdado7 djdado7 is offline
Vehicle: 1995 Dodge Ram B2500 Con Van
Trim Level: Conversion Van
Engine: 1995-1997 318ci (5.2L) Natural Gas V8 200hp 430lb/ft
djdado7 is on a distinguished road
Default After overhaul is done
Ok guys here is my problem now.Ram2500 done overhaul on my tranny but now tranny would not down shift,trying to contact him got me nowhere.. before i was able to drive van with problem upshifting from 3-rd gear to 4-th ..now cannot drive van at all cause keep shutting down all the time.and sound of differential sound like metal to metal been rubbing. He stated that maybe is fuel pump ,or low engine oil,or that something went wrong while overhaul is done..I did read online that if some of this symptoms happens it would cause someone change ECM unit.. don't know what to think any more.Got car but don't got car..... any ideas what could be wrong
Old 01-21-2013, 03:53 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
There is nothing wrong with the transmission, I have never had a failure on ANY REBUILD! You brought the van to me and it hadn't any motor oil! I put oil in it for free. It should not have any issues downshifting! The only thing I can think of is that the front servo isn't releasing when downshifting on the 2-1, however if this was the case you wouldn't be able to upshift the 2-3 without binding. Remember it shakes on the downshift and most likely because the engine is trying to stall out, my guess is there is an issue with the torque converter and or the engine.
