Old 01-18-2013, 09:11 PM
BIGDAN1980 BIGDAN1980 is offline
Vehicle: 2012 Dodge Ram
Trim Level: Crew Cab Big Horn
Color: Sage Green Pearl
BIGDAN1980 is on a distinguished road
Default HELP PLEASE!! 2012 Ram 1500 Crew with 6in RCX Front Drive Shaft Problem!!!
I have a 2012 Ram 1500 crew i had a 6in RCX lift put on and i have 35in nitto trail grapplers on XD Rockstar rim's. I had the lift and tires put on at 17,000 miles and my truck has 31,000 miles on it. I had noises coming from the front end so i took it to the dealer and they decided the inside of the front driveshaft came apart so they had me take it to the shop that installed the lift to check the angle and he said it was good so dodge put on a new one. Today i took it back to the dealer and they say its the front shaft again!!! Anyone else having this problem? I love my truck just hate it making noises Thanks for any help!
Old 01-20-2013, 01:02 AM
candy08's Avatar
candy08 candy08 is offline
Trim Level: Sport 4x4
Rep:213
Nope, 35k on my lift and not a hiccup
[CENTER][SIGPIC][/SIGPIC]
Old 01-20-2013, 11:03 AM
dwanton's Avatar
dwanton dwanton is offline
Vehicle: 2013 power wagon 2500 loaded
Trim Level: crew cab loaded
Rep:80
dwanton will become famous soon enough
truck looks awsome .
maybe you can stop by a shop that makes drive shafts and ask them what they think . maybe they can custruct you a nice one that doesnt get all rusted up .
2013 power wagon 2500 - 5.7 everything but leather.
Old 01-20-2013, 12:20 PM
I guess im going down to advanced driveline in fl to get them to fab me one. I talked to rcx yesterday and they say they have had no problems but the shop that installed my lift said that they have this problem with the 2012 models because they have changed the front drive shaft setup? Either way im just going to get a drive shaft made because it makes alot of noise! Thanks
Old 07-11-2013, 11:20 PM
24dsxual 24dsxual is offline
Vehicle: 2012 Dodge Ram 1500 Sport
24dsxual is on a distinguished road
I'm on my 3rd front drive shaft with only 35000 kms on the truck....this is a nightmare. Did you fix your problem with the custom drive shaft? Mine keeps failing at the CV joint.
Old 07-12-2013, 12:12 AM
2012ramsportellis's Avatar
2012ramsportellis 2012ramsportellis is offline
Vehicle: 2015 dodge powerwagon
Trim Level: power wagon
Color: blue streak pearl coat
Rep:94
2012ramsportellis will become famous soon enough
He we go again with the rcx and there lack of testing on these rams , I also went threw this front driveshaft issue on my 2012 ram 1500, I caught mine early noticed the bad vibration after my 6 inch lift was installed , rcx sent me out new front differential drop brackets which lowered the angle on the driveshaft and now I have no issues since up front , they are well aware of this issue but still sell the 2012 324s kit with there orgional brackets , but I also have a nightmare with my rear driveshaft pinion angle , that destroyed my rear u joints as-well for this they sent out adjustable rear upper control arms and I still cant get it set right to where the wobble is gone . And I now also have my rear springs sagged , all this with only 4500 kms on this kit . I would not recommend this rcx kit to anyone ! the front brackets they sent out for free and paid for the install , the rear issue they sent out the arms and I was left with a bill of close to $500 for install and new u joints .
RCX 6" RCX 1.25" bl Bilsteins at 1.4 Mufflex 18" go-rhino dominator 2 side steps
Old 07-12-2013, 01:10 AM
I have left Davy at rough country a few voice mails and emails, I have also sent pictures to rough country and have not received any replies. I have read people have had no issues at all but I have also found others having the same issues. I have paid out more in replacement parts then the cost of the lift. 2012ramsportellis who did you deal with to get the correct diff drop brackets? The shop contacted rough country and was told they were unaware of any issues for 2012.
Old 07-12-2013, 03:02 AM
Wh1t3nukle's Avatar
Wh1t3nukle Wh1t3nukle is offline
Vehicle: 2000 Ram ORE 4x4 5.9L
Trim Level: Laramie SLT
Rep:55
Wh1t3nukle will become famous soon enough
For your rear issue, did you ever get the angle measured at the tcase?
You have slip yoke at the tcase with ujoint correct?
Get an angle finder and measure it at the tcase. That angle must be same (no more than 2 different) at the axle pinion. Take that angle and get shims at an angle to rotate the pinion back down. The shims will go under your leaf springs, on top of the perches.
Example Shims
00 Ram 1-ton ORE; 3" BL; 14" coilovers; ARBs, 37" Toyos; R/T Camshaft; Mopar M1; Custom long arms, sliders and bumpers; 12K Winch; York +5g OBA
Old 07-12-2013, 03:27 AM
Rep:2616
it is always the angle of the dangle
in this case the dangle is the drive shaft
i believe that someone was misinformed about having no angle was good
a perfectly straight drive shaft & universal joints is not the best way to do it
this is a simplified explanation
http://www.hotrodhotline.com/md/html..._harmonics.php
Old 07-12-2013, 11:28 AM
Well just got back from the shop and they say "if rough country says they haven't had any problems then it must be faulty drive shafts" this is a joke. Is there anyone out there who has had similar problems and found a fix? That would like to go into detail about how it was fixed?
