Old 01-31-2013, 08:00 AM
closetoreality closetoreality is offline
Vehicle: 05 Hemi
closetoreality is on a distinguished road
Default Wheel fitment on '05 RAM 4x4
Looking at a set of 20x10's with an offset of -25mm. Tires are 275/65/20's curious if these would clear on an '05 4x4 with stock suspension.
Also if anyone has this setup or something similar a picture would be great, trying to see how it would look pushed out of fenders on stock rubber.
Old 01-31-2013, 08:53 AM
Clifford17 Clifford17 is offline
Vehicle: 2012 Dodge Ram
Rep:176
Clifford17 has a spectacular aura aboutClifford17 has a spectacular aura about
You should have no problem fitting them in your truck.... I had 275/65/20 on my 08 with 1" wheel spacers with no issues.
Old 01-31-2013, 01:01 PM
NBCarbone's Avatar
NBCarbone NBCarbone is offline
Vehicle: 2005 Dodge Ram 1500 Daytona
Trim Level: Daytona
Color: Go ManGo
Rep:22
NBCarbone is on a distinguished road
Send a message via Skype™ to NBCarbone
I'm running 305/50/20's on mine with no spacers - Yea I know it's not 65's but these tires do take up a lot of room but there's no rubbing at all.
Old 01-31-2013, 11:15 PM
gopackgo69's Avatar
gopackgo69 gopackgo69 is offline
Rep:20
gopackgo69 is on a distinguished road
He is looking at -25 offset on 10" rims, I think it might rub. If you like the rims/tires, look into a 2" spacer to level the front and you will be fine. I used to run a 275/65/20 on stock rims and had no problem, but i did have a level kit. Stock I think you would possibly rub at the rear fender area and maybe anti sway bar.
2014 4x4 Hemi sport , 3.92, Pro-comp level 2.75", Rear Fox 2.0, 1.5" springs, Diablo 93 Tuned. Toyo AT2 295/65/20
Old 01-31-2013, 11:24 PM
NWRQC's Avatar
NWRQC NWRQC is offline
Vehicle: 2007 RAM
Rep:64
Inner clearance won't be the problem you will have plenty of room between the wheel and suspension. I've never ran this set-up but I do believe that you will run into issues with rubbing on the frontair dam and possibly the rear of the wheel well.
Compared to stock wheels, the ones you want will stick out 68mm more, or roughly 2.75".
Like gopackgo69 pointed out, it's the width and offset that will be the issue, not the tires.
2007 6.7| EFI-Live | ARP | T4 S366 | AFE | Draconian tuned TCM | Thuren
