Old 01-11-2013, 04:44 PM
Ramsportslt2011 Ramsportslt2011 is offline
Vehicle: 2011 Ram 1500
Color: Metallic grey
Ramsportslt2011 is on a distinguished road
Default Vibration in 4x4
So I have a problem. My 2011 dodge ram 4x4, in auto 4x4 and 4x4 lock, it vibrates really bad when taking off from a stop sign on dry pavement. Now I have a leveling kit in just 2.5" in front and 1.75" in the rear. I brought it into the dealer and they instantly said it was the leveling kit because of the pitch it put on the cv shaft. But I disagree because it did before had the kit installed. Any info will help. Thanks
Old 01-11-2013, 06:08 PM
Otterdriver's Avatar
Otterdriver Otterdriver is offline
Vehicle: 2013 Big Horn Crew Cab
Color: Western Brown Pearl
Rep:160
That's unfortunate, but as others have stated in the past, a certain percentage of the 4th Gen Ram's have this issue "from factory" , which sounds like your in that percentile, even without a levelling kit, a certain percentage have no problems until they install the levelling kits and then the vibrations show up and then there are the certain percentile that are the lucky ones that dodge the bullet completely, having no issues even after they install either a levelling kit or lift. Total crap shoot. I would have at least done a levelling kit on mine if these symptoms didn't exist with these trucks. Sorry for your luck.
Old 01-12-2013, 06:49 PM
Chickenhole's Avatar
Chickenhole Chickenhole is offline
Vehicle: 2011 ram sport
Rep:21
Chickenhole is on a distinguished road
the level kit is definitely making it way worse. I had a 2.5 in my 2010 and it was horrible, never would do that again. I think evrey ram with a level 2.5 has this problem, people are just lying to themselves. All parts are the same lol
4" MOPAR LIFT, BILSTEINS@2.1, 12" REAR BILSTEINS, 1.5 TGC COIL SPACER, 325/60/20 NITTO TERRA GRAPPLERS, AFE STAGE 2, XD ROCKSTARS
Old 01-12-2013, 07:16 PM
primo spaghetti's Avatar
Vehicle: 2014 Ram Sport
Color: Maximum Steel Metallic
Rep:910
your problem IMO is that youre using 4 wheel drive on dry pavement...especially obvious to me since you claim to have noticed the vibration prior to your level kit install.
that is why youre having vibration...it is not meant to run in 4 wheel on dry pavement.
4x4, vibration
