Old 03-16-2014, 09:14 PM
Originally Posted by macc08 View Post
another great suggestion.
We use stuff called DC4 here at work. Works awesome
Ever since I started using it , I've had zero issue
Old 03-16-2014, 09:28 PM
tachel403's Avatar
tachel403 tachel403 is offline
Vehicle: 2011 Dodge Ram sport quad cab
Trim Level: sport
Color: blue
Rep:71
tachel403 will become famous soon enough
A word of advice however, grab one of the "waterproof" or "all weather" fuse holders for the fuse in your engine bay. And at about $5 from any hardware store, its worth its weight in gold.
Reps!
Will do thank you for pointing that out
Old 03-17-2014, 01:19 AM
Ryank's Avatar
Ryank Ryank is offline
Vehicle: 2009 Dodge Ram
Rep:199
Awesome truck! Love everything you have done.
Old 03-19-2014, 12:33 PM
06PowerWagon's Avatar
06PowerWagon 06PowerWagon is offline
Vehicle: 2006 Dodge Ram 2500
Trim Level: Power Wagon
Rep:26
06PowerWagon is on a distinguished road
Originally Posted by tachel403 View Post
Here i have changed all the old yellow stock bulbs on the truck over to the led bright white. i did the map lights,dome light in back of cab,bed light,added ina 60" led tailgate bar license plate bulbs were changed out for leds, and the back up lights were also. the hid's i did low beam and fog lights 35 watt 8000k . i regret not going with 55 watts. by no means are these are these dim or dull, THEY ARE BRIGHT AS HELL. but i just like lots of light so i would go with 55 watts.
OOH you have two dodges :P very nice
Smile even if its a little creepy
Old 04-10-2014, 09:27 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
so recently my hids died on my drivers side low beam and my fog light has been out for a while. so ive gone ahead ordered and recieved 4 kits of 55watt 8000k hids for fogs and low beams. im also gonna be taking my headlights apart painting them and reinstalling this weekend.
Old 04-10-2014, 09:35 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
First got myself some supplies from Canadian Tire! total 50$
this is the exact paint scheme i am going for. will take my time mask it off and hopefully all goes well
Old 04-12-2014, 10:39 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
well i started friday night and just finished up here early saturday night. took about 11 man hours of actual work. and about 5 hours watching paint dry and waiting for the oven to heat up and bake my lights.
first off remove your lights and take out all the electrical wires and lights, along with the dome covers
this is the stuff that i removed from the headlight itself.
next heat your oven to 210 Fahrenheit and bake lights for 10 minutes. if you need to put the light back in the oven. place it in for 5 minutes after the first initial timing.
id recommend putting your light on a cookie tray so that its not sitting against the racks in your oven.
full size oven is required for these headlights.
the housings are now removed
i only pried my lights open on 3 sides with a screw driver and while still hot slid the housing s out.
this is the side i left alone and did not bother unsealing.
Old 04-12-2014, 10:44 PM
Great work so far
Old 04-12-2014, 10:49 PM
Hemitron Hemitron is offline
Vehicle: 2010 Dodge Ram 1500 Laramie
Hemitron is on a distinguished road
If those die on ya, try looking for a set of Beamers HID, they aren't a cheap product. Those custom headlights are looking great!
Old 04-12-2014, 10:56 PM
tachel403's Avatar
Trim Level: sport
Color: blue
Rep:71
i then scuffed my lights with some green scotch brite. as seen in my first picture of supplies.
i then primed each light and let them dry
i painted each light all black first with 3 coats and let dry.
i taped off the outline of where the blue paint would be going.
i filled in the big spots with newspaper as to make sure no blue would get on the black areas of the light.
three coats of blue color matched paint later and some drying time.
masking tape and news paper removed and now to let it fully dry for about another 2 hours.
Lights are now dry so i reinstalled my side markers. i like the look of them. some people just leave them out, but up to you.
this time around im installing 55watt hids 8000k
i reinstalled the housings back together. i heated the lights up in the oven for 10 minutes at 210 degrees so that it was easier to work with. i put clear silicone back inside the groove the light sits in and sealed it together. i then also put a nice good bead all the way along the outside edge and made sure it was sealed.
put your lighting harness back in and attach your bulbs. or in my case i installed my hids at this time.
drivers side
passenger side.
Hids installed and all back together
front of the truck with all four hids on , and my 42" light bar
I hope you guys enjoy all the pictures and this new look. its well worth the time and effort to do it yourself. cost me around 50 dollars minus hids. better than paying hundreds for someone to do it for you. now you have the pride when someone asks where did you get those lights, you simply say i did them all myself.
