Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain Engines, Transmissions & Differentials > 5.9L V8 Specific Topics
Old 01-25-2013, 12:33 PM
FilthyDog's Avatar
FilthyDog FilthyDog is offline
Vehicle: 1999 Dodge Ram 1500
Trim Level: SLT Laramie
FilthyDog is on a distinguished road
If you look down through the throttle body (you have to take off the air filter housing) and can see oil pooling at all, then you have a blown plenum gasket.
Mods: Hughes FI Intake, Stainless Steel Short Headers(generic ebay), Rebuilt Cylinder Heads, K&N Cold Air Intake, IAT Mod, Hughes STAGE 1 MODIFIED O.E.M. THROTTLE BODY, High Flow exhaust, LineX Bed Liner
Old 01-25-2013, 03:28 PM
Maddevill Maddevill is offline
Vehicle: 2003 Dodge Ram 1500 Quad
Color: Grey
Rep:25
Maddevill is on a distinguished road
I would get in the habit of checking the oil more often than just when it's time to change it. Could prevent BIG problems that way....
Old 01-28-2013, 12:25 PM
MDReptile MDReptile is offline
Vehicle: 98 Ram 1500 5.9L QuadCab
MDReptile is on a distinguished road
So to check for this oil pool, i can easily remove, then put back in all the stuff to get in there? Won't have to replace seals or anything? And yes your right, I'll be checking rather frequently now that I've got problems showing up.
Anyway, if getting in to check for plenum leaks is do able by A less experienced person like me, I'll do it. Does that video i posted on the last page show how to do it properly?
Old 01-28-2013, 01:34 PM
FilthyDog's Avatar
Default You Can do it!!
Yes you can easily remove and put back the air filter housing. All you need is a Phillips. Take of the housing (big black plastic hose) Look down into the intake manifold (use your hand to actuate the throttle body and with your other hand shine a flashlight down.) If there is any pooling of oil at all then you have a blown plenum gasket.
The video you posted starts with the air filter housing and the throttle body removed. So no, it does not show you how to take of the air filter housing.
Old 01-31-2013, 09:17 PM
Ok thanks for clearing that up for me, I'll go out and have a look tomorrow!
5.9l, hard brake, oil pressure, sport, stop
