Old 01-16-2013, 06:17 AM
MDReptile MDReptile is offline
Vehicle: 98 1500 5.9L QuadCab Sport RWD
MDReptile is on a distinguished road
I think its still got oil left, but its getting pretty black from being late for a change. Might be lower since i last checked. I'll do the oil change first here next week, then if the light remains at stops, the send unit.
Old 01-16-2013, 10:12 AM
elinmon1976's Avatar
elinmon1976 elinmon1976 is offline
Vehicle: 2004 Ram 1500 quadcab 2wd
Color: tan
Rep:65
elinmon1976 will become famous soon enough
My 98 5.2 did this and I was losing oil due to a plenum leak as well. Was going through about 3 quarts every othe week or so.
2004 Quad cab 2wd 4.7L
1998 Ram Reg Cab, 5.2 auto 2x4
Flowmasters to make her rumble...LOL
Old 01-16-2013, 01:04 PM
DOZER's Avatar
DOZER DOZER is offline
Vehicle: 2006 Ram 2500 Quad cab 4x4
Color: Atlantic Blue
Rep:140
DOZER will become famous soon enoughDOZER will become famous soon enough
Send a message via Yahoo to DOZER Send a message via Skype™ to DOZER
WOW 3 quarts every other week. Mine was only loosing a quart a month.
'06 2500 ST 4x4 Quad cab, Vararam CAI, Bed/Hood stripes, Vent visors, Bully tailgate lock, Moto Metal 909 18x9, Nitto Terra Grapplers 295/70/18 HBS 2" level, Bilstein 5100's, Bushwhacker flares, 5000K HID's, Diablo Trinity 87 tune, LineX, Bakflip F1.
Old 01-16-2013, 03:47 PM
Umm yeah I'm pretty sure that's not happening, but your making me nervous lol, I will double check the oil level when I go out later. I think its really an electronic thing, and at this point I really hope so! Sounds like the other possibilities are much more severe. What's a plenum leak mean? Does that mean like burning off oil?
Edit: ok read up in that, sure hope I'm not experiencing this, checked the oil, both running and off, does seem low when off, but perhaps even too much while its running... I'll try to get under the top off the engine to check the possibility of plenum leaking going on... Gulp...
Old 01-18-2013, 12:06 AM
Howells's Avatar
Howells Howells is offline
Vehicle: 1999 dodge ram sport 5.9l
Trim Level: sport 4x4
Rep:19
Howells is on a distinguished road
If your overdue for an oils change you might be down abit in oil,this is normal. Change out the sensor that's the most common problem. For the needle dropping down and your light coming on. I have also seen these sensors leak abit also causing the same problem.
Old 01-18-2013, 11:04 AM
Well here either later today, or early next week I'll be doing the oil change finally, and possibly tranny fluid if I'm feeling ambitious. I'll take it for a spin and brake hard and turn tight, and if that light beeps at me I'm gonna turn around and get that sensor right away. I'll be sue to let you guys know how low it really turns out to be, and if i have to get that part put in or not.
Old 01-18-2013, 11:10 AM
Rep:1845
If this is happening when you brake hard or turn sharply, my money says it's not a sensor issue. You probably have a sludge/pickup/pump issue.
Old 01-19-2013, 02:29 AM
Oil change did the trick. Old oil must have been screwing with the sensor... Was low, probably to be expected this late to change. Thanks for all the help guys!
Edit: oh hey, obviously don't forget to change the filter, and if your oil is not getting old, it could be really low! Do check both of those first if you get this problem, now its running like a champ. I used castrol high mileage Dino oil if that matters at all.
Old 01-19-2013, 09:18 AM
Rep:1845
If your oil was that low between changes, I'd bet you have a blown plenum pan gasket. Fix that and your consumption problem will go away.
Old 01-20-2013, 06:58 PM
Hmm, possibly, and i never got around to checking that. I'll have to have a look - I should see a little puddle of oil in there under the plastic coverings right? I googled a bit about that but didn't find any pictures or anything. Edit: found this video,
Is that what you mean?
5.9l, hard brake, oil pressure, sport, stop
