Old 01-04-2013, 04:25 PM
robpayneusaf's Avatar
robpayneusaf robpayneusaf is offline
Vehicle: 2010 Dodge Ram 1500 TRX4
Trim Level: TRX4
Rep:195
robpayneusaf has a spectacular aura aboutrobpayneusaf has a spectacular aura about
Default Bilstein 5100 Leveling Before and After with pics
When making the decision to install Bilstein's 5100 ride height adjustable shocks on my 2010 TRX4, I searched this forum top to bottom looking for a thread that gave a good before and after, but was not able to find one. So I am putting this out there for anyone that is in my situation in the future.
I installed the Bilstein 5100 shocks in the front and rear of my truck. The ride height adjustable shocks in the front were set to 2.8". I have read that setting your front shocks to 2.8" will give you a "Death Wobble" in 4WD HI while under hard acceleration. But, I have not experienced any such wobble. I've tested under every situation I could think of (wet roads, dry roads, snow, ice, mud), and still there is no wobble. Lucky me I think it could be due to the fact that the TRX4 stock suspension is already about an inch taller that normal 4x4's. So I wasn't changing the angle as much as someone without the TRX4 package would be. But maybe I just lucked out. Well enough chat, let's get to the pictures.
Here are my new shocks as they came out of the box.
Before, with my stock shocks installed, my ride height looked a little like this.
Front - 35 3/4"
Rear - 39"
I had about a 3 1/4" rake.
After, with the Bilstein 5100 shocks installed in the front and rear. Front set to 2.8"
Front - 37 3/4"
Rear - 39 3/8"
My rake is now at about 1 5/8"
Overall I am very happy with my upgrade. The ride is better than on the stock shocks, and in my opinion it looks much more aggressive. The height difference should allow me to fit a little larger tire when it is eventually time to replace mine. Let me know if you have any questions. I'll leave you guys with a couple more pics... because well, everyone loves pictures!
Before
After
Old 01-04-2013, 05:35 PM
Shock Shock is offline
Vehicle: 2012 Ram 4X4 CC
Trim Level: Lone Star 10th Anniv
Shock is on a distinguished road
Looks good. I priced the shocks at $100 each on Amazon and found a place local that would installment them for $50 but $175 to realign. Need to check on some more prices before pulling the trigger.
Old 01-04-2013, 08:37 PM
hoyter hoyter is offline
Vehicle: '11 1500 sport 4x4
Trim Level: sport 4x4
Color: mineral grey
Rep:13
hoyter is on a distinguished road
I ordered mine from AJ @ Autoanything. They should be here Monday. I'm thinking about tackling the install myself to save money. I'm still deciding on the 2.1 vs 2.8 debate.
Rob, good looking truck. I thought the TRX could not take the full 2.8 up front due to the factory "lift" as those trucks are an inch taller. That's awesome if your not getting any vibration in 4wd.
Shock, $175 seems like an awful lot for an alignment.
Old 01-04-2013, 09:29 PM
I agree on that being too much for the alignment. I believe that it's supposed to be realigned to the factory specs after the level anyway. Anyone should be able to align it.
Old 01-04-2013, 09:35 PM
joelwalls's Avatar
joelwalls joelwalls is offline
Vehicle: 2011 RAM 1500 sport
Trim Level: sport
joelwalls is on a distinguished road
give it a go its not to hard i did mine myself with a buddy in a few hrs i did however pay fords shop to compress the srings and swap the seats cause i dont deal with my local dodge dealer unless its warranty work
Old 01-05-2013, 02:40 AM
You say your TRX is 1" taller? From what ive heard it is too (TRX in general), it is. But your front starting point pics were 3/4" lower than mine.
Mine was 36.5 up front and 39.25" in the rear.
This is why you're not experiencing the slight wobble. But it's better for you and probably means your starting angles were better
Got pics of your CVs?
Old 01-05-2013, 09:53 AM
chadster21's Avatar
chadster21 chadster21 is offline
Vehicle: 2012 dodge ram
Trim Level: sport fully loaded
Color: charcoal grey
Rep:108
chadster21 will become famous soon enoughchadster21 will become famous soon enough
i too would like to see the CVs... truck looks good lots of room for some bigger tires now
6'' rcx lift, 1.25'' rcx body lift, pro comp adjustables at 2.75'', 1.75'' tgc coil spacer. 37'' toyos on 20'' fuel hostages. mufflex 14 cai
Old 01-05-2013, 11:33 AM
h2oman's Avatar
h2oman h2oman is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Express 4X4
Rep:308
Outstanding. It's really gonna look great with new tires. Great job.
333Half the beast
I used to be
Old 01-05-2013, 12:28 PM
Trim Level: TRX4
Rep:195
I'll get you pictures as soon as I can. But it's going to be a crazy weekend, so it may be a couple days!
Old 01-05-2013, 12:38 PM
Whenever you get a chance man.....but yea, it sounds like it will be similar to mine set at 2.1 which is not bad at all.
I had minimal to none at all at that setting.
Given our starting points were 3/4" difference I can see how its working for you
5100, bilstein, level, leveling, trx4
