Old 01-01-2013, 11:16 PM
tommyt tommyt is offline
Vehicle: 2008 Dodge Ram
Color: Grey
tommyt is on a distinguished road
Default leveling kit
will a 2008 ram 4x4 leveling kit work on a 08 ram 2wd?
Old 01-02-2013, 08:19 PM
Biggesthorn's Avatar
Biggesthorn Biggesthorn is offline
Vehicle: 2009 dodge ram
Trim Level: Bighorn
Rep:14
Biggesthorn is on a distinguished road
doubtful but im only about 80% sure
5" lift 35" mud grapplers 20x12 fuel hostages rbp grille rbp steps nfab front and rearrunners
Old 01-07-2013, 12:56 PM
BLACK07 BLACK07 is offline
Vehicle: 2007 Dodge Ram
Trim Level: SLT (QC/SB)
Rep:36
BLACK07 is on a distinguished road
Are you talking about lifting the front or lowering the back? a rear lowering kit (shakles) should work because the rear end uses leaf springs on both. A front lift kit would be different because the front end is where 2wd and 4wd are different. If it has anything to do with struts or spindles it wont work because they are different. Any kind of spring spacer SHOULD work but it might not be the correct height. A 4wd sits higher stock than 2wd so you would need to lift a 2wd higher to get a level so a 4wd kit might not lift it high enough to get a 2wd to sit level.
Did you find a good deal on a 4wd kit or are you just having trouble finding a 2wd kit? There are lots out there if you need help finding one let me know.
2007 Black Dodge Ram SLT QC/SB
DIY is the way to go!
level kit, lift, ram, suspension
