Old 12-20-2012, 12:34 PM
BIGDAN1980 BIGDAN1980 is offline
Vehicle: 2012 Dodge Ram
Trim Level: Crew Cab Big Horn
Color: Sage Green Pearl
BIGDAN1980 is on a distinguished road
Default 2012 Ram Crew 1500 W/6in RCX LIFT HAS NOISE IN FRONT END?
I have a 2012 ram 1500 crew cab 4x4 that has a 6in rcx lift sitting on 35in nitto trail grapplers. I had a noise coming from the front drive shaft so i took it to my dealer and they had to check the angle but everything was to specs so they have replaced that about 2 months ago.
Now i have a popping noise and sounds like it would be a cv axle. Has anyone had any issues like this after lifting their new Ram's? Thank's
Old 12-20-2012, 01:15 PM
twenty12ram1500's Avatar
twenty12ram1500 twenty12ram1500 is offline
Vehicle: 2012 ram 1500
twenty12ram1500 is on a distinguished road
I have not had any problems with my lift i am running the same set up as you.... popping could be the ball joints if they werent tightened all the way or if they are worn out, or the cv joint,
-do you hear the popping when you go over a bump or up a drive way ramp?
Old 12-20-2012, 01:21 PM
I here the popping only when im driving slow and it's a steady pop pop pop. And its all the time thats why i thought maybe the cv axle.
