Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Suspension
Suspension 1st Gen Dodge Ram Suspension Problems and Questions
Old 12-18-2012, 08:30 PM
Mzm0054 Mzm0054 is offline
Vehicle: 2002 dodge durango sport
Trim Level: sport
Color: silver
Mzm0054 is on a distinguished road
Cool popping noise when I turn?? HELP!
Hey guys, I have an issue with my 02 durango sport 2wd 4.7...I recently replaced the upper and lower ball joints, sway bar links and tie rod ends along with the shocks. I then took it to sears to get an alignment and ever since then something has been popping when I turn at slow speeds specifically parking lots or driveways..it sounded like it was the right side at first but I also hear it on the left I think, I know I can feel it in through the pedal or floorboard. I grinded the knuckles so I did not replace the entire control arms and I think they have bushings as well but I cant tell if they are shifting. I read something about the steering column but I just dont know how to isolate and identify the problem. btw I never took it back to sears because they closed down before I could. I graciously thank anyone in advance who can help me with this problem
Old 12-22-2012, 02:24 PM
2RAMSAM's Avatar
2RAMSAM 2RAMSAM is offline
Vehicle: 09 Hemi Ram
Rep:13
2RAMSAM is on a distinguished road
Did you damage the wheel bearing when you removed it to change your ball joints? I.E. pounding on the outer flange to get it out of the steering nuckle.
Old 12-22-2012, 02:41 PM
Rep:1845
Pretty unlikely considering this is a 2WD and the bearing doesn't require removal for ball joint replacement. Start looking for the problem by going over every component you had loose and making sure they're all tight.
Old 12-22-2012, 05:53 PM
Trim Level: sport
Color: silver
Yeah the wheel bearings are fine, there is some power steering fluid i think leaking from the passenger side of the gear box right there where the rubber boot attaches to it and there are two small lines connecting to it as well. Think this could be related? The sound only occurs at very low speed and and when turning the wheels, like pulling in or out of a driveway...I pulled off the front wheels today and checked everything and it all seemed tight...I think it has something to do with the alignment..
Old 01-13-2013, 09:23 PM
Mojack's Avatar
Mojack Mojack is offline
Vehicle: 2012 Ram 1500 ST
Color: Deep Cherry Red
Rep:65
Mojack will become famous soon enough
I once installed a new ball joint so tight that it wouldn't allow grease to be installed with a grease gun. It would pop several times while making a low speed turn. I finally got it to take grease after some driving.
2012 Ram 1500, 1986 RamCharger,
1972 Duster 340, 1965 Valiant 340
Old 01-13-2013, 09:52 PM
Rep:2616
You may want to go to someplace that does alignments for a living
i notice that there is a place near you
it may be worth checking out
Fowler's Alignment And Brake Service, Inc.
911 12th St
Phenix City, AL 36867
http://www.fowlersalignment.com/
Old 01-14-2013, 11:41 AM
Trim Level: sport
Color: silver
thanks, I had Sears grease my ball joints but should the boot around the ball joint balloon afterwords? because mine do not. Also, I was thinking about this the other day, do you think it could be something on the steering shaft b/w the steering wheel and the gear box??
noise, parking, popping, steering, turning
