Old 12-16-2012, 04:45 PM
kelticknotts kelticknotts is offline
Vehicle: 2010 Ram 1500 Big Horn
kelticknotts is on a distinguished road
Default Rough country combination lift questions...
Has anyone used this kit? It's a 2.5in suspension lift and a 1.25in body lift combo... It's 249.00.... It's designed to work with the stock rims which is fine with me. Any input would be great... I'm not looking to go big but alittle more than a leveling kit. Thank you in advance ...
Old 12-16-2012, 05:46 PM
Ghostknife's Avatar
Ghostknife Ghostknife is offline
Vehicle: 2013 Dodge Ram
Color: Grey
Engine: 2013-20?? 409ci (6.7L) Cummins Turbo Diesel 385hp 850lb/ft (Aisin ASC69RC Automatic)
Rep:51
Ghostknife will become famous soon enough
Theres a couple people that have, im sure they will post pics up eventually
Old 12-17-2012, 11:24 AM
express2012 express2012 is offline
Vehicle: 2012 RAM 1500 4X4 QUAD CAB
Trim Level: EXPRESS
Color: RED
Rep:45
express2012 is on a distinguished road
I had ordered this kit but while researching I actually called and cancelled it what I did was ordered just the body lift and the rear 1.75" spacer for the rear that came in the leveling part instead of putting the spacers in the front I put bilstien adjustable 5100 s in the front set at max 2.8.. i am very happy with out come. the struts canbe removed and reinstalled if mechanically inclined but a shop will have to compress spring to change and do an allignment. the body lift again if your mechanically inclined will take about 6 hours. I just got about 3000 miles since install and rechecked fastners and all stayed tight, the bumpers raise by drilling a couple new holes in brackets no big deal but have extra drill bits. the tailpipes if you have dual will raise easily, only thing i can think of negative is you either have to trim the lower fan shroud or leave it off I chose to trim would rather it still be there but again no big deal go for it it is as close to a 4" lift you will get without spending 1200.00 and you can keep factory wheels 275/65/20 look good (34.1x11.00)
Old 12-17-2012, 02:45 PM
Bully's Performance's Avatar
BULLYS PERFORMANCE
Vehicle: MOPAR
Rep:931
I agree completely with his recommendation of a bilstein level here is a link if your interested http://discountautoperformance.com/s...7b5bfccd51cc8f
Thanks
Jeremiah
Discount Auto Performance
Old 12-18-2012, 11:03 AM
FSTASFCK FSTASFCK is offline
Vehicle: 2010 Dodge Ram Big Horn
Rep:108
FSTASFCK will become famous soon enoughFSTASFCK will become famous soon enough
Bilstein's maxed out, 1.25" Body Lift, and 1" Rear Spacer and I love it!!!
