Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - General Discussion > Dodge Ram Special Edition Models > Dodge Ram Vans
Dodge Ram Vans For discussion of Dodge Ram Vans. Please use our existing technical areas for driveline discussion, etc.
Old 12-05-2012, 05:39 PM
Mutt's Avatar
Mutt Mutt is offline
Vehicle: 2012 Ram 1500 4x4
Color: Deep Cherry Red
Mutt is on a distinguished road
Default 1988 B250 Ram Prospector
Here's my '88 Ram Van. I picked up during the summer of 2011. It's an one owner van that only had 12k original miles on it. It has a 5.2 TBI, overdrive automatic, cold R12 a/c, tilt steering column and cruise control. It was totally unmolested when I got it. Since then I've added some goodies..
Old 12-05-2012, 05:43 PM
Mutt's Avatar
Here's a link to the build process from Vannin.com
http://vannin.com/threads/ubbthreads...2/1/Mutt_s_Ram
Old 01-04-2013, 10:18 PM
ITSARAM's Avatar
ITSARAM ITSARAM is offline
Vehicle: 2009 Dodge Ram
Trim Level: TRX-4
Color: Detonator Yellow
ITSARAM is on a distinguished road
So, it was unmolested and then you molested it?
Old 01-05-2013, 08:59 AM
stubie82 stubie82 is offline
Vehicle: 2012 Dodge Ram 2500
Trim Level: Power Wagon
Color: Mineral Gray
Rep:36
stubie82 is on a distinguished road
Sharp lookin van. Good find!
Old 01-21-2013, 05:09 PM
ramvan2500's Avatar
Trim Level: SLT - 2500
Rep:128
Hey mutt, how you doing. The van is looking good, I too have been working on my van. I'm designing a new suspension system for the van and a new engine as well.
Old 02-02-2013, 08:48 AM
Mutt's Avatar
I fondled it just enough to make it happy
Old 02-02-2013, 08:49 AM
Mutt's Avatar
What are you doing to the suspension?
Old 03-30-2013, 06:15 AM
Wolfwasp's Avatar
Wolfwasp Wolfwasp is offline
Location: I live in 3 places in this world. Atikokan, Ontario. Canada./Larkspur, California/Waikiki, Hawaii
Vehicle: 2002 Dodge Ram(Conversion) Van
Trim Level: Conversion
Color: Green
Wolfwasp is on a distinguished road
Send a message via Skype™ to Wolfwasp
Hey Ramvan2500! Good to see you are still active here. I was gone for a while but I am back. Still have my van.
Next up, the diff.........
Thought I would check with you before jumping in as I have no idea.
Had a heart attack 6 months ago but survived. Just getting back to normal.
Old 03-30-2013, 04:35 PM
ramvan2500's Avatar
Rep:128
Glad to hear you survived, I bet it was a very scarey experience! Just take things slow.
I still have my van also, it is in storage for my spring break. I have to replace the front end soon, cannot even drive the thing without ending up in the other lane.
Anyways, for the differential I am assuming you are just changing out the fluid. Well the first thing to do is layout the tools and parts.
Tools: Wrenches, Sockets, and a Torque Wrench to torque the housing cover bolts (25 ft-lbs)
Parts: Housing Cover Gasket, Gasket Sealer, 2-3 Quarts of Gear Oil (I run 75W-140 to 85W-140 especially on high mileage differentials, oh yea Valvoline Conventional or Durablend.
If you have a Limited Slip Differential you will need friction modifier, I highly doubt you have Limited Slip because not many people who got the vans opted for it, and since yours is a conversion van I am almost certain since most van converters rarely order them with LSD. But just to be sure check the white build sticker under the hood, should be attached to the underside of the hood.
1. Put a pan under your axle housing.
2. Take all of the bolts off except the top two, these you just want to loosen.
3. Hit the cover lightly with a hammer to free it.
4. Let all the nasty oil drain, then remove the top two screws and the cover.
5. Inspect the ring gear for any chipping, if their is chipping I recommend you have the ring and pinion gear replaced. Inspect the spider gears in the carrier also for any damage and replace if damaged.
6. Clean the old gasket off of the housing and housing cover.
7. Clean the shavings magnet, this magnet sits on the bottom of the housing on the inside of course.
7.5 Take your housing cover and paper gasket and try to find a way in which the holes align perfectly, then set aside the gasket.
8. Prepare the housing and housing cover by covering both surfaces with gasket sealer, then place the paper gasket onto the housing cover being sure that the holes align perfectly.
9. Install the cover and finger screw the bolts in.
10. Take out your wrench and just wrist tighten everything, then take your torque wrench (set 25 ft-lbs) and torque each bolt working in a zig-zag pattern.
11. For me, have a beer; but for you, grapefruit juice.
12. Fill the differential with oil, if you have a Limited Slip Differential be sure to put the friction modifier in first, then the oil.
13. Put the filler plug back in and then go for a ride!
Be sure to bottle the old oil and bring it to your local oil collector, in my case autozone.
If you have any troubles you can just PM me or email me and I will respond in the drop of a dime.
Old 03-30-2013, 04:52 PM
ramvan2500's Avatar
Rep:128
Oh I never even noticed this post, I am designing a 4-Link suspension. I was originally intending to just design and build some traction bars but these vans have some horrid squat under acceleration and some sick hop under sudden hard braking. So I said well 4-link can give me the best of both traction bars and anti-squat, so I been hard at work in my notebook doing all the math for the materials to make sure that they don't fail under load, and in AutoCAD Mechanical I been designing and performing the FEA on the various mounting brackets and links. This is something I was working very hard on but I took a break, I only recently got back on the designing. I figured out how to make the mounting for the front links so the cross member portion clears the driveshaft including it's movement of course, the mount also serves as a cross member which will really make the rear end rigid, the only problem is the weight is just severe, the whole suspension system seems like it would weigh a good 150-220lbs. Most of the weight being in the brackets and cross member because all that is 1/4" steel plate or the cross member being 2-1/2 x 2-1/2 x 1/4" steel square tubing.
