Old 11-28-2012, 03:01 PM
Salkin Salkin is offline
Vehicle: 2012 dodge ram 1500 crew cab
Trim Level: Sxt
Salkin is on a distinguished road
Default Best fog light solution?
I have a 2012 crew cab with out fogs and want fogs but with a factory look is there any way do do this with out getting a new bumper? And that works well?
Old 11-28-2012, 03:45 PM
Rep:2616
The plastic insert can be removed & cut out to fit on any front bumper
just cut out where the tow hooks would go & make or modify some brackets for the fog lights
for $400 or less you can purchase a new bumper outer piece, with the fog light & tow hook setup
The fog lights & tow hooks would of course have to be added by you
Old 11-30-2012, 08:52 AM
Emorris69 Emorris69 is offline
Vehicle: 2011 Ram 1500 SLT
Rep:40
Emorris69 is on a distinguished road
If you read my post on my fog light build. http://ramforumz.com/showthread.php?t=124275. You can see how I added not only the factory fog lights but also a mopar kit. If you go to your dealer and just order the mopar kit in there it is very simple to install and you just need a mechanic to activate the switch once your all done. I did the work in no time at all outside in the cold. Just be careful when you cutting out the plastic grill. Since these photo's I have added the tow hooks. The only thing I neglect in my post is I have since used 2 sided tape to make the plastic piece fit nicer.
2012, crew, fogs, lights, sxt
