Old 02-17-2013, 09:58 PM
emjohn4 emjohn4 is offline
Vehicle: '12 Ram Sport CC / '02 Durango
Rep:154
emjohn4 has a spectacular aura aboutemjohn4 has a spectacular aura about
Originally Posted by Hemipwrd View Post
I have got to check this out!!! Mine started doing this about a week ago and its driving me crazy, I've been pushing and pulling on everything inside the cab to get it to go away and so far no luck. Hope this will be the solution.
Mine started last week as well - after 9 months of ownership and 6,200 miles.
Perhaps this weekend I'll pull these "blocks".
Old 05-27-2013, 02:57 PM
APSTRAM's Avatar
APSTRAM APSTRAM is offline
Vehicle: 2012 Ram 2500 Crew Cab 4x4
Color: Deep Cherry Red
Rep:85
APSTRAM will become famous soon enough
I have owned my 2500 for two weeks and the noise from the passenger side dash area was gettting worse by the day.
After reading this post this morning I went out to the garage and lifted the cowl then reached under it and pulled off the loose melted plastic that was the spacer.
I took the truck out for a test drive on a rough road and the noise is gone. Thank you.
Old 11-28-2013, 07:55 PM
NUG NUG is offline
Vehicle: 2012 Ram 1500ST
NUG is on a distinguished road
Great post. These trucks are noisy in all the wrong ways. Thanks for the heads up!
Old 01-10-2014, 04:39 PM
RAM SPORT CREW's Avatar
RAM SPORT CREW RAM SPORT CREW is offline
Vehicle: 2012 Ram Sport Crew
Rep:110
RAM SPORT CREW will become famous soon enoughRAM SPORT CREW will become famous soon enough
My truck started making this noise this fall and only at highway speeds. Just got done popping those 2 little plastic pricks out, as well as the hardened glue. On the drivers side I had a little rectangular piece of dense foam that I also took out. Highway test soon will reveal if the noise is gone, but I am pretty confident it will be quiet!
Old 01-11-2014, 01:52 AM
SHANERR's Avatar
SHANERR SHANERR is offline
Vehicle: 2012 Ram
Trim Level: EXPRESS
Color: WHITE
SHANERR is on a distinguished road
Thanks for the 411
Old 02-13-2014, 01:50 AM
ptesmoke ptesmoke is offline
Vehicle: 2012 Power Wagon
Rep:58
ptesmoke will become famous soon enough
i recently just started getting a creaking noise when going over certain rough roads in cold weather. really hoping this is the cause. I can however push on my headliner and the creaking stops...
Old 02-13-2014, 06:54 PM
oldhp's Avatar
oldhp oldhp is offline
Vehicle: 2014 Express 3.6/8 speed auto
Color: WHITE
Rep:902
oldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to beholdoldhp is a splendid one to behold
The yellow "spacers" are put there from the factory for windshield alignment while the glue/sealer sets and are supposed to disintegrate. If they are still there gently remove them.
How do I know??? When my windshield was replaced recently I asked what these things were that are all broken up just hanging there.
2014 Express 3.6/8 speed/3.55 gears...Work Truck
2012 Equinox 2.4...Wife's Ride
"Life's hard, it harder if your stupid." How would you know?
Old 02-13-2014, 09:49 PM
Turbovsix's Avatar
Turbovsix Turbovsix is offline
Vehicle: 2010 Dodge Ram Crew Cab
Trim Level: SLT Big Horn
Rep:83
Turbovsix will become famous soon enough
Huge post - I've been dealing with this issue for a while and will dig into it. And my issue only arises in cold weather - goes away when it's hot which makes sense since that glue would soften a little I guess.
Rich -
2010 Dodge Ram 1500 SLT Big Horn, Crew Cab HEMI - all stock!
2012 Jeep Grand Cherokee Limited
Old 02-13-2014, 10:29 PM
oldhp's Avatar
Color: WHITE
Rep:902
The guy that installed my windshield used tape stuck to top of cab holding it up while glue/sealer took a set so it wouldn't slide down. Said they never used the factory stops at bottom to hold up windshield.
Old 02-14-2014, 08:13 PM
Ram Dude's Avatar
Ram Dude Ram Dude is offline
Vehicle: 2013 RAM 1500 5.7 SPORT
Rep:27
Ram Dude is on a distinguished road
Subscribed for later use..........
