Old 11-22-2012, 05:24 PM
shawnbo shawnbo is offline
Vehicle: 2012 Dodge Ram Sport Crew Cab
Rep:16
shawnbo is on a distinguished road
Default Creaking coming from windshield
I finally found what was causing the annoying creaking around the dash area on the front window of my 2012 Ram Sport. When its cold and the body of the truck flexes I would hear this creak, creak, creak coming from the lower windshield area. I thought it was the dash, but I was wrong. It is actually two clips that have glue applied to them to help hold the windshield in place during time of fitment. I see no purpose for these especially since they seem to be loose anyway, once the windshield is in place it should not sag. I popped both clips out, the creaking is now gone. Remove the wipers, and cowl covering the lower windshield and you'll see what I'm talking about. Pics are below. I also lined the cowl with some 3M weatherstripping tape as the cowl tended to make noise too. Finally, all quiet in the cab. I might put a piece of rubber in place of the glue and replace the clip, but I can't see what purpose they are serving at this point.
Old 11-22-2012, 07:16 PM
Asur Asur is offline
Vehicle: .
Rep:4371
Thanks for the heads up , If mine starts that I will know where to look
Old 11-22-2012, 10:26 PM
DRsilverram's Avatar
DRsilverram DRsilverram is offline
Vehicle: 2012 Dodge Ram Big Horn
Rep:56
DRsilverram will become famous soon enough
My windshield does the same thing, not all the time even when its cold?
I will look into what you described..........Thanks for the info!
Old 11-26-2012, 03:33 PM
Rep:16
Mine did it mostly when it was cold, but not all the time either. The sun heats up that glue and makes it pliable and it doesn't creak. I noticed it when the truck body flexed hitting a bump or on an uneven surface. Its nonsense that I paid $50K for a truck that I have to fix because the dealer is too stupid to find the root of the problem. Now all the is left is the crooked steering wheel. QA inspection team should be fired.
Old 11-30-2012, 03:42 AM
mrtosh mrtosh is offline
Vehicle: 2014 dodge ram
Rep:12
mrtosh is on a distinguished road
I have this creak as well. Mostly up in the passenger front dash by the window. Mine goes away when pushing in the dash though. Dk if it would be those clips?
Old 11-30-2012, 11:36 AM
Rep:16
Doesn't sound like its the clips, you can always remove them and see.
Old 11-30-2012, 01:42 PM
dino76033 dino76033 is offline
Vehicle: 2012 dodge ram
Trim Level: Laramie Longhorn
dino76033 is on a distinguished road
Mine also has the crooked steering wheel. To the left. I've gotten a noise a handful of times on the driver side dash. I've pressed everywhere and nothing changed. Maybe that's it.
Old 12-04-2012, 07:40 PM
Hemipwrd's Avatar
Hemipwrd Hemipwrd is offline
Vehicle: 2012 Dodge Ram HEMI
Trim Level: SLT Big Horn
Color: Mineral Gray
Rep:103
Hemipwrd will become famous soon enoughHemipwrd will become famous soon enough
I have got to check this out!!! Mine started doing this about a week ago and its driving me crazy, I've been pushing and pulling on everything inside the cab to get it to go away and so far no luck. Hope this will be the solution.
Old 12-07-2012, 03:48 PM
LowUFO's Avatar
LowUFO LowUFO is offline
Vehicle: 2012 Dodge Ram 1500
Trim Level: Sport Crew
Color: True Blue Pearl
Rep:1105
Not the issue for me. The clip is glued down tight. Don't have to remove the wipers.But it would make it easier to remove the cowl completely, though. Just push the popits up from under the cowl using something flat (I used the flat side of a flathead screwdriver). There are three of them and a module that acts like a fourth. Then just pull up. You can actually see the clip through the cowl vent on the passenger side (where my noise issue is emanating from) when you have the hood up. I did remove some excess hardened glue. But I'll wait and see if it keeps happening.
Simon
Old 02-17-2013, 02:34 PM
HemiGuy12 HemiGuy12 is offline
HemiGuy12 is on a distinguished road
Just removed the driver side windshield alignment block and this fixed my noise. Thanks
