Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.9 Liter V8 > Exhaust
Exhaust 5.9L Exhaust Discussion
United Radio
Old 11-22-2012, 12:12 AM
Dukeboy's Avatar
Dukeboy Dukeboy is offline
Vehicle: 1999 Ram 2500
Color: Red/Silver
Rep:13
Dukeboy is on a distinguished road
Default Headers For 2nd Gen rams.
Anybody now of a manufacturer that makes a quality, Long tube header for my 99 2500 4WD truck? I looked at the "Y" pipe the other day and geesh, I'm amazed it gets any fuel mileage at all. Must be like 2" pipes or something. Anyway, if not, I have a couple sets of car/truck headers I can cut up I guess and make my own.
Old 11-27-2012, 08:46 AM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
Hmmm, I have looked all over and it seems there's nobody that makes a full length header for these 4WD trucks. I have studied the chassis layout and i think there's room for loing tubes. If I get a prototype set made up, I'll be sure to post pics.
Old 11-29-2012, 06:53 AM
goldmember goldmember is offline
Vehicle: 1998 Ram
Trim Level: NA
Color: NA
goldmember is on a distinguished road
Pacesetter makes a long tube header for these trucks. Check Ebag.
Old 11-29-2012, 08:55 AM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
I wonder if they are 2WD or 4WD?
Old 11-30-2012, 05:32 AM
Vehicle: 1998 Ram
Trim Level: NA
Color: NA
Says they fit either.
Old 12-03-2012, 01:22 AM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
Gonna try 'em out and build my own "Y" pipe. Will post pics of all after completed if interested.
Old 12-06-2012, 08:56 AM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
Here's a picture of headers.
Old 12-10-2012, 08:10 PM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
For any who want to see how I did it yesterday, here are a few pics of the short comings of the Pacesetter brand Headers for these trucks. While not a $1000/set they are fairly priced and fit "ok". I think the "Jig" they have set up puts too much bend angle where they come down under truck. Pacesetter claims to install them from UNDER truck. I found it much easier to install from top.
I had to make up a bracket to hold the driver's side off the front driveshaft when on the ground. The pass, side had to be tweaked a little for more clearance at the Servo housing part of trans case. Overall, I'd reccomend them to anyone looking to boost Fuel Economy. Mine did pretty good on MPG (As that's why they were installed).
Old 01-03-2013, 02:07 PM
LRS360's Avatar
LRS360 LRS360 is offline
Vehicle: 1997 Dodge Ram
Trim Level: 1500 Laramie
Color: Green
LRS360 is on a distinguished road
Where did you put your primary and secondary O2 sensors? Are you still running a cat? Looks lik it should help that 360 breathe a lot more now.
Old 03-12-2013, 11:13 PM
Dukeboy's Avatar
Color: Red/Silver
Rep:13
UPDATE:
Primary O2 Sensor is only reading the pass. side. As long as the pass. side runs clean, no code. No real way to read both banks unless wiring harness is cut into. Screw all that.
WOO HOO!!! Va. has lifted the "No True Dual Exhaust/cats" law. We can now run true duals as long as we are running DUAL CATS.
I will be running DUAL cats. No cats in picture as I haven't gotten them yet. The REAR (Secondary) O2 sensor is only for Uncle Sam/Tree huggers.
(Only tells what the converter cleaned up, and has No ill effects on Air/Fuel ratio). Next to go is the Factory Muffin.
