Closed Thread
Old 11-17-2012, 12:31 AM
storeboy storeboy is offline
Vehicle: 2009 Dodge Ram
Rep:19
storeboy is on a distinguished road
So what does it take to replace the thrust plate or the timing set from a 6.1 to a 5.7? Is this something that can be done by your average home mechanic with a little bit of knowledge or something that needs taken to a professional to do?
Old 11-17-2012, 12:43 AM
Rep:1845
It's not difficult to do, but I have all the right tools and nearly 20 years experience on my side. It's really hard to define what exactly the "average" home mechanic can do, so I would say if you want to upgrade and you aren't 100% sure you can do it, take it to a professional.
  #43
Old 11-17-2012, 01:23 AM
I push the skinny pedal
Rep:3277
It's easy enough to do if you have the right tools. There are several great resources online with how-tos. I just did a head/cam/intake swap on mine this spring that required removal of the timing set, so it's not all that difficult. An impact is your best friend though. If you really want to do it let me know and I can forward the links to you in a PM. The 6.1L thrust plate just bolts right into place.
Kurtis
  #44
Old 11-18-2012, 12:31 PM
RansRAM's Avatar
RansRAM RansRAM is online now
Addicted to the Z
Color: PX8 Black
Rep:2471
I'll take the Links Kurtis if you could PM me. Want to see at least what is involved with this and the parts list. Would rather fix it sooner rather than Too Late if it's not too hard to do !!
  #45
Old 11-18-2012, 01:27 PM
huntergreen huntergreen is online now
Trim Level: sport
Color: green
Rep:643
are we sure this is the solution?
  #46
Old 11-18-2012, 01:44 PM
Gantman's Avatar
Gantman Gantman is offline
Trim Level: Tradesman 4x4
Rep:974
CdnoilRAM; if you please sir, I too would like a PM on this repair/replacement.
And thanks again RamTech for the update and detailed info bud.
Old 11-18-2012, 02:15 PM
frickenbored's Avatar
frickenbored frickenbored is offline
Vehicle: 2012 R/T, 2000 Ram Off Road
Trim Level: R/T / Larmie
Rep:73
frickenbored will become famous soon enough
Not sure I'd be digging into these engines if your still under warranty. The dealer I work at will no questions asked void a warranty if they see any parts on your engine that shouldn't be there.
About a year ago I had a 2007 ram 2500 hemi that had lifetime powertrain warranty on it, it came in because it was spitting tons of oil through the pcv system. He had broken piston rings in cylinders 1 and 3 that took out his cylinder walls, long story short he needed a short block. Well he had this weird ram air intake thing on his engine that had these big 5" air intake tubes that went behind his bumper. The service manager took one look at this thing, found a little bit of water in one of the tubes, called chrysler, they sent someone out to look at it and they voided his warranty right there, nice $5000+ bill for him.
Anyway its true that a timing chain thrust plate is harder to find than a air intake but if you bring your tuck in for a major engine repair and they find that 6.1L plate, unless it was installed by a dealer they have every right to decline your warranty. Just something to think about.
I say if its under warranty, let it blow up, you'll get a new engine. Now when my warranty on my 2012 r/t is over and if i decide not to buy the max care I will put the 6.1L plate it just for some piece of mind.
Chrysler Dealership Engine, Trans, Axle "Heavy" Tech of 3 years
Check em' out:
  #48
Old 11-18-2012, 02:23 PM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
^^^^ That's some great advice you have posted. Of course I would not be doing anything until my warranty has expired.
  #49
Old 11-18-2012, 02:54 PM
Gantman's Avatar
Rep:974
Yes I agree, if you want to maintain your warranty, then run it til it breaks. Will you feel the same about your truck after you get it back? Only time can tell. But for those that don't mind breaking out the wrenches, pullers, and pans and want to do the preventative repair/replacement yourself; go for it man, I sure won't be mad at ya.
Old 11-18-2012, 03:52 PM
Copperhead Ram Copperhead Ram is offline
Vehicle: RAM
Rep:33
Copperhead Ram is on a distinguished road
RamTech, since this problem is on Chrysler's radar now, do you think they'll be fixing the issue soon so the assembly plants aren't pushing out more of these problem engines?
Closed Thread
