Old 10-31-2012, 09:30 PM
Rep:4072
Arrow Is This Part Compatible/Interchangeable?
In response to there being a vast number of questions on whether certain parts are compatible/interchangeable between trim levels or model years, this thread is for those of you looking to do swaps from one truck to another and want to know will it fit? Will this part work on my truck? If you want to know will a bumper from a 1997 fit your 2001, here is where you can find out! All we ask is that questions that are not relevant to the topic be posted in the appropriate section of the forum!
Old 11-02-2012, 11:53 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Default 2nd Generation Engine
Table of Contents
2nd Generation -
Engine
Transmission
Suspension
Wheels
Body
Interior
3rd Generation -
Suspension
SRT10 Suspension Swap
brad
Interested in one of my mods?
POPER's Avatar
POPER POPER is offline
Vehicle: 2001 Dodge Ram
Trim Level: SLT Laramie
POPER is on a distinguished road
Engine Replacement (318ci/5.2L)
“Any 1992 or newer 318/5.2 Magnum shortblock is a bolt-up affair. Have fun.” (re: 2001 Ram)
Source Thread: http://www.ramforumz.com/showthread.php?t=124459
5.2 to 5.9L Swap
“The balance weight on a '97 is on the flexplate, so use the 5.9 flexplate and any zero-balance converter (5.2/5.9, 1996 or newer). Use matching computer.” *
* “As long as you're sticking with the same trans I know from experience that it doesn't matter which ECM you use.”
Source Thread: http://www.ramforumz.com/showthread.php?t=121050
Also…
“i do believe mostly everything is interchangeable but you will need a new fly wheel and harmonic balancer seeing as the 318 is internally balanced and the 360 is externally balanced”
Source Thread: http://www.ramforumz.com/showthread.php?t=97404
Fuel Pump (Re: 1996)
“looks like in the 1500 series Rams, the fuel pump is the same
(96) 1996 Dodge Ram 1500 5.2L V8 & (96) 1996 Dodge Ram 1500 5.9L V8
Part Number: 1966-07006127
Brand: Airtex
Notes: Fuel Pump Module Assembly
It looks like a few other parts are also interchangeable
http://www.mopartsracing.com/parts/ram.html
Source Thread: http://www.ramforumz.com/showthread.php?t=95711
Timing Chain, Cover, and Water Pump 2001 5.2-5.9L
“I already back tracked the timing chain/sprocket set and that is compatible.”
“Believe it or not the 3.9, the 5.2, and the 5.9 are interchangeable on the timing cover.”
Source Thread: http://www.ramforumz.com/showthread.php?t=118581
2001 5.9L Laramie SLT - En route to "custom"
POPER's Avatar
Default 2nd Generation Transmission
Transmission Swap (Re: 2001 318-360 compatability)
“The 46 went "RE" in 1996. Any 1996 or newer 46RE will swap.”
Note: “The number refers to the torque rating. Essentially 42,44= low, 45= medium, 46=high, 48=OMG!
The "R" stands for rear wheel drive. The "E" means electronic valve body, as opposed to the earlier 46RH which had a hydraulic valve body.”
Source Thread:http://www.ramforumz.com/showthread.php?t=124469
Also… (Re: 99 318-360 compatability)
“Well Mike the trans are interchangeable . But the torque convertors are different . The one from the 5.9 is externally balanced . If you use that in the 5.2 , you will have a vibration from the motor . Yes the rear main is accessible with the trans out . I am a believer , if it's not broke don't fix it .”
Source Thread: http://www.ramforumz.com/showthread.php?t=60269
POPER's Avatar
Default 2nd Generation Suspension
1500-2500 Suspension Swap
“A guy at my local autozone has a 94 1500 with 2500 suspension on it. he told me everything off 2500 and 3500 will bolt right up to a 1500 exept for the rear leaf springs. but all you have to do is bend the mounting ears out a little to fit in the bigger 3 inch wide leafs. im swaping everything while i have it torn apart so its probly guna turn into a week long project. hers what im doing,
- 2500 shocks and struts
- 2500 coil springs
- 2500 leafs
- wheel bearings
- ball joints
- u joints
- tie rod ends
- and all other bushings up front.”
Source Thread: http://www.ramforumz.com/showthread.php?t=86136
Old 11-02-2012, 12:00 PM
POPER's Avatar
Default 2nd Generation Wheels
Wheels:
1986-2012 Ram 150/250/1500 5 lug rims will fit on 2nd Gen trucks **
http://boltpatternguide.net/Dodge/Do..._Patterns.html
** Translation: 3rd and 4th gen lug nuts will not fit on 2nd gen studs **
All Rams by year: http://www.discountedwheelwarehouse.com/Dodge_2___Vehicle_Bolt_Pattern_Reference.cfm
POPER's Avatar
Default 2nd Generation Body
Rear Window:
“They are interchangeable as a unit from 94-01. The difference being 94 to 96 has two sliders that meet in the middle. 96-01 has a single slider. I might be a little off on the year, but the footprint is the same if you pull the whole thing and aren't looking to just replace one pane.”
“My '97 has dual sliders. I had thought that the dual slider switched to the single slider in '98 when they redesigned the interior?”
Source Thread:http://www.ramforumz.com/showthread.php?t=100928&highlight=rear+window+swap
Front Bumper (Chrome):
1996 brackets will not bolt directly to the 2001 frame, however the 2001 brackets will bolt to the 1996 bumper.
This weekend I decided to finally put a straight bumper on the truck - I chose one off of a '96 1500 assuming that this bumper will fit on a truck with the exact same bumper; I was mistaken (as was the salvage yard). When I went home to install the bumper, everything lined up perfect except the front two brackets where the three bolts mount the bracket to the frame.
I removed the '01 brackets off my old bumper and they fit the '96 bumper no problem. THEN everyhting bolted right up.
**Note: I suggest swapping the carriage bolts for hex bolts as vice grips and eventually a grinder were needed to remove the brackets from both bumpers because the carriage bolts just kept spinning.
POPER's Avatar
Default 2nd Generation Interior
Dash:
“I believe the 94-97 are the same, 98 on its own (see below), and then the 99-01s.
The 98s are different as they have a cig lighter where the air bag stuff is on the 99-01, easy fix, remove the lighter. Also the 98 has a pull out switch, 99-01s are a turn knob, it still fits but its a smaller opening.”
Source Thread: http://www.ramforumz.com/showthread.php?t=73098&highlight=dash+interchangea bility
Headliners:
“Then again not all Gen 2 parts are interchangeable. Take something as generic as a headliner. I tried a '97 in my '95 and it was 4 inches too narrow. I still haven't figured that out.”
Source Thread: http://www.ramforumz.com/showthread.php?t=100928&highlight=rear+window+swap
Overhead Consoles:
1994-1998 Exact
1999-2002 Exact
2002-2012 Different set-ups, same general footprint
Source Link: http://www.jimsautoparts.com/mopar_performance_dodge_truck_magnum_interior.htm# roof%20and%20overhead%20console
Old 03-28-2013, 09:44 PM
d2evan d2evan is offline
Vehicle: 2008 dodge ram
Trim Level: sxt
d2evan is on a distinguished road
Exclamation 2008-2004 5.7L hemi swap HELP
im currently parting out my 2008 dodge with 5.7L hemi, a man came to buy the motor he has a 2004 dodge ram 5.7L hemi (blew up) he isn't sure if my motor would fit in his , dodge didn't do any mount changes ect from these years did they? it should work correct? both 4x4
Old 04-09-2013, 01:46 PM
boxinggsxr boxinggsxr is offline
Vehicle: 02 dodge ram 4x4 4dr
Color: blue/silver..dallas cowboy colors
boxinggsxr is on a distinguished road
what about gen 3? mine is a 02 ram 1500 4dr 4x4 but with a 4.7 i had read the 4.7 are considered the 3rd gen? so how would i know what brush guards from other ram years will fit mine? thanks
