Old 10-24-2012, 07:54 AM
dig dig is offline
Vehicle: 2010 1500 Dodge Ram Crew Cab
Trim Level: SLT- Big Horn
Rep:19
dig is on a distinguished road
Default Air Lift
I installed one about 6 months ago, family complained about the ride, I now have 0 air in the bags, I know it is not good on the bags, but I will take the chance, the ride is now back to normal and hopefully they will be there when needed.
Old 10-24-2012, 02:13 PM
Originally Posted by ONOutdoorsman View Post
I don't find it too stiff. You can notice a difference but it is not bad at all. That is the only PSI setting I have tried so far. Maybe 10 would feel the same. My wife doesn't even know I put them on. I love the extra cornering ability. It is so worth it. That is MO of course but for $90 to eliminate the sag, you can't go wrong. Now I wish I had the Sport seats with a little more bolster support. Then I would really be
I don't doubt it's worth it.
I'll be ordering it shortly.
Just curious as to why members run them at different psi. That's all
Old 10-25-2012, 01:05 AM
mcampbell mcampbell is offline
Vehicle: 2012 Dodge Ram Sport
Color: Mineral Gray
Rep:13
mcampbell is on a distinguished road
Good luck with the decision!
Old 10-26-2012, 07:17 PM
06Stang's Avatar
06Stang 06Stang is offline
Vehicle: 2014 RAM 1500 Sport
Color: Granite
Rep:40
06Stang is on a distinguished road
Just installed the kit on my dad's '12 with the two inch spacers in the front. Running the truck at 15psi and completely leveled. Looks very good and handles like stock. He's using the bags for his large camper trailer.
Chrysler Jeep Accessories Tech
Old 10-26-2012, 07:28 PM
sebber sebber is offline
Vehicle: 2014 Ram 3500
Rep:14
sebber is on a distinguished road
I have the kit installed and I love it. I don't encourage this at all...but...with my camper I am maxed out to the truck capacity (i know, i know, already looking to trade for a 3500) but for now I am sitting at the 1500's limit and the air 1000's help a ton! When the trailer is on the truck without the Weight Distribution hitch, i inflate the bags to 25-27 psi and the trucks sits nice and level! Worth the 90$ and then some!
2012: 2012 Ram 1500/ RV:2012 Palomino S17
2013: 2012 Ram 2500/ RV:2013 Denali BH311
2014: 2014 Ram 3500/ RV:2014 Sabre QSIK35
A truck a year keeps the doctor away!
Old 10-26-2012, 10:38 PM
Thanks for the feedback!
This will help others as it is doing for me
Old 10-26-2012, 11:06 PM
LeftCoast's Avatar
LeftCoast LeftCoast is offline
Vehicle: 2012 Ram
Trim Level: Sport Crewcab
Color: True Blue Pearl
Rep:248
LeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura aboutLeftCoast has a spectacular aura about
I put them in the 2nd day after I bought the truck. I put the truck on jackstands and then let the axle down to make the install nice and easy. I used a heat gun on the bags to make them squeeze up between the springs a bit easier too.
I run about 25lbs of air when towing my trailer ( about 5,000lbs) and its sits nice and level.
I run about 5lbs of air when empty.
It was around $80. On the cheap its the way to go...I highly recommend it.
For a bit more money the TLC system is pretty sweet looking. Fullsize airbags and with an air compressor to raise or lower would be nice.
Probably the only 2wd Blue Crew in Canada.
Mod list Debadged, Airlift 1000 airbags, Cabin Air Filter Mod
, BT Catch Can.
Old 10-28-2012, 08:30 AM
Rep:14
Nice Install pics Leftcoast! I went the lazy way... I just jacked up the rear end by setting my floorjack under the hitch and just lifted enough to take pressure off the coils, then I squeezed in the bags...this part went pretty smooth...running the lines was a different story, i found there wasn't much room to work with the fender wells. But all in all it took me less than an hour to complete the job! No inboard compressor for me as well, I just pump them up with my shop compressor. I inflate them on camping weekends and then drop the psi's to 5 when not towing! Great product... really stabilizes the rear end!
Old 10-31-2012, 04:27 PM
Hovenator's Avatar
Hovenator Hovenator is offline
Vehicle: 2012 Dodge Ram 1500 CC 4x4
Rep:31
Hovenator is on a distinguished road
I need a set of these as I tow a trailer 4 days a week for work. Can these be used woth a 1.5" lift spacer on the rear spring?
Old 10-31-2012, 05:56 PM
LeftCoast's Avatar
Vehicle: 2012 Ram
Rep:248
Can't see why not. If its just a spacer on top of the spring then the spring would be the original size....right? If it has a hole in the center of it , that would make the install nice and easy, otherwise you would just have to drill one in the middle of that spacer.
, BT Catch Can.
